So I got myself a wideband gauge and it comes with a 0-5v data logging output, however it gives no information about what software to use or where to get it, so I did a little google search to no avail.
I'm asking if anyone use's the function, and if so explain how, like did you make your own usb cable and what software did you use?
In my search I did find some software for PC (I have a mac) but it never mentioned anything about a usb cable.
also does the software need information form the obd2 plug?
Links appreciated!
Cheers - Daniel
https://www.sau.com.au/forums/topic/450144-wideband-data-logging/
What wideband is it? Typically they give you the software.
You could try you put something together with an arduino board, but to make loggign useful it has to include at least rpm, throttle position and preferably boost.
stock ecu with a apex neo piggy back
heres a link to the sideband I bought - http://www.ebay.com.au/itm/360746100476?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
not sure if its a popular brand or not, but its called "EVO" gauge, I like the seller, and I like the race tech gauges, so I just bought this off him.
and yeah I thought it would have came with software/ or at the least instructions, I'll see if that brand has a website and go from there, but thanks for the help guys, and I couldn't imagine trying to make my own board or whatever, however it did come with a sheet with readings like 0v = 10.0 afr 0.25v - 10.5 afr etc etc to 5v = 20.0 afr or something like that anyway.
also the r34 uses the consult port, not obdII
Edited by vetter2769
So if its only a 5v output then I believe you will need some sort of medium capable of turning 0-5v signals into an output a laptop etc could read. My AEM wideband has a 0-5V output which is hooked up to my Link G4 and it also has a serial output that you can plug directly into a laptop (if you wire a serial plug to it)
This is why it prpbably didnt come with software, 0-5V outputs from the gauge are usually to just output to an ECU that can read the signal
I'm not sure what it was intended for, it may very well be to output to an ECU, I found a few arduino boards on ebay, but they all log data to a fat32 or SD card, and they still don't incorporate RPM.
I'm sure I've seen some guys doing there own tuning with a piggy back who use the data logging system to tune, heres the thread here - http://www.sau.com.au/forums/topic/327734-apexi-afc-neo-safc-tuning-issues/
note the graphs.
Cheers - Dan
That guy's wideband IS the datalogger. It's all Innovate gear.
All you have is the wideband. You need a datalogger as a separate thing.
What you should probably do is sell the cheapo wideband you have to someone ehow wants it but doesn't want to datalog, and buy something like the Innovate jobby that will actually get you what you need in something more practical.
Your alternative is to move to an ECU that will accept the 0-5v input and log it along with everything the ECU itself is doing. Then you can get the data out of the ECU.
Either way, you are going to have to spend some money. A standalone logger would probably be lowest cost if you can find one that will easily pick up what other signals you need to log. RPM is relatively easy, but many other things like load, boost, TPS etc are more work (and expense) to pick up, especially if you're doing it on the cheap. The Innovate style logger is essentially the same as the standalone option in that respect. Easy to grab RPM, not so easy to grab everything else.
Thanks mate, I never bought the gauge with the intention to data log in the first place, but because it mentioned that it came with it, I was hoping it would be relatively easy to do it.
I will keep the gauge and I probably won't tune my car myself, if I do, it will only me minor adjustments till I get my nistune or power fc.
Thanks to those that responded :)
Im guessing they meant you could data log through an ECU. The Power FC will allow you to do it through FC-Edit but you will need the datalogit and laptop connected to do it. Where as an ECU like a Link will log it all the time (as long as its wired right and logging is enabled)
I agree with the above. If you REALLY want to log it then get an AEM UEGO or an innovate wideband gauge that has proper support for it. Although I dont see much point in logging it with what you have. Best off just using the gauge while driving. Glancing at it every now and then
An alarm for lean would totally suck unless referenced to boost. Otherwise it will go off every lift of the throttle. ....
Yeah exactly. Off throttle the gauge will go out of range (lean) because there should be no fuel going into the engine
There is no point having an alarm on a wideband because it fluctuates so much. I highly doubt if it only has a 0-5v output that it would reference boost so I would just keep the alarm off. If it is mounted on the A-Pillar (just assuming) then usually you will notice if it is not right under load.
Personally I'd ditch it and get a proper one. The Innovate gauge is a pretty nice bit of kit, and costs less than $200 from memory. Same with the AEM unit like I have. Not sure what the deal with the Innovate's are now, but the good thing about the AEM gauge/Wideband sensor, is that it never needs free air calibration. I know the old Innovate stand alone wideband kits reqired free air calibration, but not sure about the gauge kits.
http://www.wide-band.com/content/apsx-d1-wideband-controller-and-g1-led-afr-display-full-kit-red
That's a bargain, and integrates to nistune.
If I was in the market I would get it for sure.
:glare: whaatttt why don't you guys tell me this before I go out and spend 200+ bucks on a wideband :(
Gauge is mounted where the stock R34 gtt gauges are. nothing on my A pillar.
Not necessarily. The factory ecu can only use a narrow band. The nistune software can utilise extra inputs to log (through the laptop)
Most wideband can simulate a narrow band output that the ecu uses, meaning that you can get rid of the stock sensor.
Thanks Ben, I just bought one for the Emo. Looks the goods.
  • Like 2
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
    • sensible choice....and all 32s should be in yellow
