After thinking over and over again and due to personal and unforeseen circumstances - it will be wiser for me to let my GTR go if the offer is fair - looking at $33k negotiable. No time wasters please... Ad is only posted on SAU and nowhere else...
No expense spared on this GTR - buy give her a remap and be happy driving her... Very reluctant but you gotta do what you gotta do... If she doesn't sell before things pick up - then i guess she was meant to be mine..
Car is in very good condition - Year 89 - Chassis is Accident Free - NSW Rego: THE.32R - till May 2015 - Gunmetal Grey - has 155k km on the clock - but i do not know the mileage of the engine - it is running well - car is currently at JLM putting together the final touches and putting the Motor back in...
Text me at - zero four three one six two one seven two six
RB26DETT :-
CP Pistons
Eagle Rods
HKS cams
Springs/Retainers
HKS Downpipe
Full custom tucked 3.5" exhaust and high flow cat made by Fabulous Fabrications (beautiful work) along with custom Hot/Cold cooler pipe.
Intercooler
Splitfire Coil Packs with New Harness and extra Grounding
Haltech Platinum Pro ECU
Bilstein (Yellow) /Eibach strut/spring combo - No leaks and no knocks
Ikeya Formula front and rear upper control arms.
Front and Rear Apexi Dry Carbon Strut Bars
Cusco Swaybars Front and Rear
Cusco 1.5w rear diff, fully rebuilt and new diff bushing installed with newer (and slightly larger/stronger) R33 half shafts
Diff oils all changed - front and rear less than 5k km
Gearbox - Redline Anti Shock Gearbox Oil (Smurf Blood) - less than 10k km
OS Giken Twin Plate Clutch and Flywheel
HICAS delete
Nismo LMGT4's with 265/40/18 Federal RSR all round - less than 1000km
Nismo Wheel Nuts
Apexi AVCR
Nardi Deep Corn
Nismo Gearknob
Full 3M Tint
HID Headlights
C's Short Shifter
Parts just installed and travelled - 0 km - being put together and putting the Motor back - 100k km service with extras
Brand New - Garrett -5's
Brand New - Cometic Exhaust Gasket
Brand New - Nismo Mounts - Engine Left, Right and Gearbox
Brand New - Nismo Clutch Slave
Brand New - HEL Braided Clutch Hose
Brand New - Nismo Thermostat
Brand New - Heater Hoses and Radiator Hoses - Silicone
Brand New - Gates Racing Timing Belt, NSK Bearings and Cam Seals
Brand New - Water Pump
Very clean, GLWS! Hope everything is ok, always sad to see when someone has to let their pride and joy go due to unforeseen circumstances =[
Thanks mate - yeah is ok - just taking a step ahead as precaution in case of anything =) Its a slow market out there...
My old car.
One of the things to note about this is that the chassis isn't like a golf ball and the sills are very straight.
Since I sold this car, I've been in the market for another one and very disappointed with the chassis' that I've seen. I didn't appreciate how clean it was when I sold it.
  • Like 2
  • 8 months later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
