ITEM #1 BRAND NEW & UNUSED BAHCO SOCKET SET 34 Piece 1/4" & 3/8” Square Drive - S330 - unwanted gift
Socket set 1/4" and 3/8" drive, Dynamic-Drive Profile.
Finish: Matt Chrome-plated.
Material: Chrome Vanadium. Case: High Density Polythene (HDPE)
Contents: 34 pieces
12 pcs 3/8" 6-pt Sockets Dynamic-Drive 10 11 12 13 14 15 16 17 18 19 20 22 mm
2 pcs 3/8" Extension bars 75 mm / 3" & 150 mm / 6"
1 pce 3/8" Universal joint
1 pce 3/8" x 1/4" Bit holder
2 pcs 3/8" Spark plug Sockets 6-pt 16 mm (5/8"), 21 mm (13/16")
1 pce 1/4" Spinner with two component handle
1 pce 1/4" x 1/4" Bit holder
3 pcs 1/4" Bits Flat 4 5.5 7 mm
4 pcs 1/4" Bits Phillips PH 1 2 3 4
6 pcs 1/4" Bits Hex 3 4 5 6 7 8 mm
1 pce 3/8" Ratchet with two component handle, 60 teeth
PRICE $65.00
ITEM #2 3A RACING POD FILTER -BRAND NEW - unwanted gift
PRICE $25.00
Contact - Ron 0416424446
Pickup - Pitt St Parramatta NSW after 730pm Mon-Fri, anytime on weekends
Edited by rondofj
Bump.. BOTH are BRAND NEW UN-USED items yep. The socket set is perfect and compact / Swedish quality with Metric sockets and bits, no Imperial waste.
Also got stock R34GTT parts:
Stock Rubber intake - $15
Fuel Pump - $35
6 X Stock R34 Injectors 370cc - $180
Pink Label R34 AFM - $80
Stock manifold heat shield -$20
RON 0416424446
Pickup - Pitt St Parramatta NSW (after 730pm Mon-Fri, anytime on weekends)
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
