Hi Guys
Up for sale is a few high performance parts I no longer need (selling my car). They are all 100% brand new, still have there respective receipts and warranties, have never been used and are all in their original boxes.
1. Garrett GTX3582 turbo with t3 twin entry 0.83 A/R housing with v band clamp $2250
2. Turbosmart Progate 50mm wastegate $625
3. Venom 500 series 3.5" inlet / outlet hight flow 100 cell cat $225
4. Tomei adjustable cam gears (intake and exhaust) $275
Contact me either by email ([email protected]), sau messaging or mobile (0468778939) anytime between hours of 8am and 10pm.
Thanks guys
Ben
Sorry guys, forgot to mention that the item is located in Brisbane and I am happy to post at buyers expense. Cash is preferred but I will accept any form of payment as long a I get my money :)
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
