hey guys,
just getting a EOI out there for my GTR
$60,000
im in no rush to sell it as its been my pride and joy for the last few years but looking at buying a house so just seeing my options.
but i will let it go for the right price
if your interested drop me a line.
also check out my build thread you will notice a lot of work and time has gone into this car and not only a lot of money and parts, quality parts.
I never bought any ebay rubbish only ever used branded names.
I don't think you need a list as you can read my build thread ( build thread link located in my signature ) if you are really interested that way you can see everything that's gone on and saves us chatting when you could probably find the answer on there... although happy to answer any questions.
car right now has 388kw @ 20psi (e85) e flex tune also has a switch with a low boost setting aswell 314kw @ 14 psi (e85)
also make 320kw @ 20psi on 98
for the right buyer the car can come with a lot of extra parts and I even have some stock parts that I have kept also if the new owner wishes to put anything back to stock.
don't hesitate to call or txt 0409076032 or pm me here
I do shift work so if I don't answer straight away im probably at work or asleep :)
Edited by kaneryan
https://www.sau.com.au/forums/topic/450204-r34-gtr-eoi/
Here is a list of what the car has,
If it has a price next to it then its what i have done to the car and purchesed myself so you can gauge an idea of the money spent
NOTE: I have not included all the time and effort and labour money which we all know is a fair bit.
$25720 is what i have spent on parts here, i have not included delivery costs in any of the prices either.
Most of my parts i purchased through RHD Japan or Import monster.
SUSPENSION AND BRAKES
DBA T3 4000 XS front and rear $900
QFM A1RM pads front and rear $250
HKS Coilovers
ENGINE
Gates timing belt $140
Tomei Cam Gears $250
Tomei type B Cams 260/9.15 $600
Tomei type A Valve Springs $300
ARP Head Studs $250
AUTECH Catchcan $200
ID 2000cc inj $700
Walbro 460Lph $200
HKS T51R KAI BB $5500
HKS Exhaust Manifold $5500
HKS GTII wastegate (60mm) $5500
K&N Pod filter $100
custom airbox cover $100
EXHAUST
Custom 4inch dump
Venom 3.5" cat 100cpi $350
HKS Super Turbo Muffler $1100
COOLING
Nismo Intercooler 100mm $1800
Greddy Hard pipe kit $600
Koyo radiator 53mm $600
Greddy oil cooler and relocation kit $900
Nismo Thermostat $80
N1 waterpump $150
ECU
Haltech Platnium Pro $2900
Haltech i/o expander $2900
Haltech wideband sensor $2900
Haltech 3 bar map sensor $2900
EXTERIOR
Z Tune Front bar / side skirts / rear pods $2100
Top secret diffuser $500
Nismo LED Tail lights $1200
TE37 TTA 19x10.5 +15 $3300
INTERIOR
Pioneer Double din Head unit $300
Focal speakers front and rear $350
Nismo gear stick
SPARE PARTS
Standard Intercooler
Standard Tail Lights
Standard cam gears
Standard camshafts
Standard Valve Springs
Standard Head studs
Standard Street Brake Pads
Rota Grid Wheels 18x10 +20
https://www.sau.com.au/forums/topic/450204-r34-gtr-eoi/#findComment-7417223
You might want to reread your add. Those prices??
$5500 for a waste gate
$2900 for flex sensor
Nice car tho
That's the total price of the group of parts, shouldn't be written on each line but still makes sense.
Sweet car man. Should sell no worries.
https://www.sau.com.au/forums/topic/450204-r34-gtr-eoi/#findComment-7417760
Nice car man love the colour interested where to buy a n1 water pump for $150 ? Pls pm me
hey mate, i bought a kit with a new timing belt and pulleys, and it was $150 to upgrade to a N1 water pump from the existing, so to that i guess it was alot more for a N1 water pump haha
https://www.sau.com.au/forums/topic/450204-r34-gtr-eoi/#findComment-7421832
  • 3 weeks later...
just to clear it up, im not interested in trades, nor a car +$20k . just simply for sale. if you dont have offers more than 50K then i will probably not reply.
reasonable offers might be considered.
Cheers
https://www.sau.com.au/forums/topic/450204-r34-gtr-eoi/#findComment-7432826
so ive had a few offers of can I take some parts off the car and replace it with stock items and that will devalue the car that way it fits into my budget....
yes of course, im keen to have a win win situation with anyone aslong as its reasonable and isn't stupid. for example, ill keep my TE37's ($3000) and take the $3000 off the price of the car.
the only thing I will not be doing is doing payment plans.
also interested in a swap for a
S14/15
180sx
GTS-T
GT-T
but need to have at least 45k my way.
open to offers but if it is below 50k don't expect a speedy response.
https://www.sau.com.au/forums/topic/450204-r34-gtr-eoi/#findComment-7437485
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
