deleting the vct oil feed passage on the bottom of the head to build a 25/30 without running an external feed to the vct starves the front journal of oil, might work ok for a while as the heads get a stupid amount of oil up there, yet its not good for the cam, the way to fit this is to take out the brass plug from behind the cam gear, and cut it off at the part where it things out before getting larger again, and then reinstall it, this allows the oil galery to goto the front of the head, if you dont do this the oil galary is blocked before the front journal.
Back on this discussion, I forgot to post my findings... I attempted to remove that brass fitting and the prick wouldn't come out.
As a move of desperation, I bought an oil squirting bottle thingy and pumped oil down those two holes on the front journal and it pushed oil into the main oil gallery along the side of the head. Not sure why it worked but as I was able to prove to myself that oil traveled straight through, I decided not to modify that brass fitting!
It's a very strange and debatable issue and I believe the best way to overcome it is to confirm using an oil can whether or not oil travels to that front cam journal.
Thanks for the advice from all the guys on here...
When you say the main gallery you mean it was comming out the other cam journals and such? If not then where. As I've had one home built rb30 come into my shop with the front cam journal completely stuffed and he hadn't done that mod when building it, and on the 3 I've done I've cut it down and havnt had any issue. I'll need to look into it more on the next one I build
  • Like 1
I pumped oil into the front feed and oil went though into the oil gallery. Refer to the photo, if you look closely you'll notice the oil.
I was so confused because Ben managed to convince me that I needed to do that mod...
This photo shows the amount of oil that went through after 2 squirts!
Guys also forgot to mention, that my mechanic who also builds engine had a spare rb25det head in his workshop and that head wouldn't allow oil to go through that passage when I attempted the same test! It is such a confusing, yet concerning matter!
Wow.
So there are differmves with the heads!
As Scott said he has seen, my engine builder has seen it yet people say its no worries, and now you have proven in your case your head is fine......
Very interesting.
Good on you for checking as it could have ended badly, now it has let others know that the heads are different somehow!
  • Like 1
http://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page-2
this page here shows the plug we talking about and theres some drawings to show where it cuts off oil supply, so im really shocked it wasnt needed in you case. amazing
My head definitely a series 1 rb25det head... The engine builder had no idea what type of head he had, said it was a drop off from a few years ago.
It's such a weird topic because sometimes it works out for people and sometimes it doesn't. I believe ultimately all people should check with an oil can. According to my engine builder guy, if the mod isn't needed then it shouldn't be done as the last thing an rb head needs is more oil to it!
I attempted this for hours man and the piece of shit wouldn't come out... Snapped a bolt in there and then tried using a tap bit and even snapped that in there. That was the point I raged and decided to test it for myself...
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
