Hey guys, I finally managed to get my engine running. Took me ages to get the timing marks spot on but I freaking did it.
The block is N/A, got a turbo head and am running turbo injectors, The intake cam is from an N/A (are they the same?) and running a series 1 TPS and using a turbo ECU. Oh, also using an N/A zorst manifold because I dont have a dump pipe yet for my turbo and the N/A mani has an o2 sensor on it.
I have a turbo gear to go on it but still waiting for some parts to arrive.
My question is, because its an odd setup, what would be the best timing for it? I dont have a timing gun to check what the timing is like, but to me it sounds like its breaking down when I rev it.
Spot the fire hazards...
Id say what ever a 25det timing is, and the break down id attribute to coils possibly
Good point. When I was checking for spark I did notice the coils with no spark plug plugged arcing out onto the coil bracket. Ive always wanted to do an external coil pack conversion might give me an excuse to do it. I just assumed the arcing was due to no spark plug in them and the spark had to go somewhere.
What......
How can you be doing stuff like this and have no timimg gun?
Who cares what timing we tell you to run, how will you run it?
Ill buy one tomorrow
Engine is nowhere near ready to get accurate with tuning.
For the moment set the CAS so she will start easily, sounded a bit too far advanced in the video.
She starts first go and idles without any issues. When I get the gun ill get the timing spot on :) (I hope)
Unplug TPS, unplug IACV.. then make sure your idle is screwed in at 650rpm (as per recommendation for a RB25DET).. then set timing at 15 degrees BTDC.
Car will run ok.. but wouldn't be nice to run.. you could blanket an additional 2 degrees on top to make your base timing 17 degrees.
It's a NA so should be fine (of course check for audible knock).
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
