Hey guys, I finally managed to get my engine running. Took me ages to get the timing marks spot on but I freaking did it.
The block is N/A, got a turbo head and am running turbo injectors, The intake cam is from an N/A (are they the same?) and running a series 1 TPS and using a turbo ECU. Oh, also using an N/A zorst manifold because I dont have a dump pipe yet for my turbo and the N/A mani has an o2 sensor on it.
I have a turbo gear to go on it but still waiting for some parts to arrive.
My question is, because its an odd setup, what would be the best timing for it? I dont have a timing gun to check what the timing is like, but to me it sounds like its breaking down when I rev it.
Spot the fire hazards...
Id say what ever a 25det timing is, and the break down id attribute to coils possibly
Good point. When I was checking for spark I did notice the coils with no spark plug plugged arcing out onto the coil bracket. Ive always wanted to do an external coil pack conversion might give me an excuse to do it. I just assumed the arcing was due to no spark plug in them and the spark had to go somewhere.
What......
How can you be doing stuff like this and have no timimg gun?
Who cares what timing we tell you to run, how will you run it?
Ill buy one tomorrow
Engine is nowhere near ready to get accurate with tuning.
For the moment set the CAS so she will start easily, sounded a bit too far advanced in the video.
She starts first go and idles without any issues. When I get the gun ill get the timing spot on :) (I hope)
Unplug TPS, unplug IACV.. then make sure your idle is screwed in at 650rpm (as per recommendation for a RB25DET).. then set timing at 15 degrees BTDC.
Car will run ok.. but wouldn't be nice to run.. you could blanket an additional 2 degrees on top to make your base timing 17 degrees.
It's a NA so should be fine (of course check for audible knock).
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
