Hi Guys,
I have an original Nissan Flare that came out of my R33 Skyline.
Not sure if this is something that is valuable or rare, but I don't think I have ever seen one for sale.
Price is $50.
Pick up from Dandenong, rather not post it, but I can for the right buyer.
PM, or text/call 0423872884. Thanks.
https://www.sau.com.au/forums/topic/450219-original-nissan-flare-out-of-r33/
Hi Guys,
Price is $50.
Pretty sure it's illegal to own one unless you have a boat. Hand it over and i can safely destroy it for you, under control environment.
Yes, illegal to own. They were supposed to be removed at import/compliance.
Definitely hazardous goods, so don't ship it.
Strangely enough, I still have mine in my car. I made sure it wasn't there when I went to Regency for the post engine transplant roadworthy though.
Edited by GTSBoy
It was in my R33 from the day I bought it... Only removed it when I sold the car lol.
Admins feel free to delete thread if its breaking any rules.
Bugger if you were local, I'd have taken it. Can't post those as they're considered explosives. I've got plenty though, when you have a boat these things expire more often than they should.
Ice also got one in my GTR that's made it over here when it got imported, I've always wondered if there rare, I've been tempted to let it off when I've been drinking lol but never bit the bullet. What's the purpose of it?
Not rare. At least if you live in Japan, and not really dangerous either. I had to buy one from Autobacs when I owned my car over there in order to pass rego inspection, as all cars must have one. Cost me about $5-10. Its a road flare, you pull the tape (or however you actually ignite it) drop it on the road and it smoulders a bright pink to alert other road users and after a certain time, eg 10 mins it burns itself out. You commonly see them on the freeways there when there are broken down cars or crashes. Pretty useful over there in fact. Cops/highway rescue staff use them too.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
