OK selling parts cheap as they must get out of my way
located in port adelaide
Original parts thread, just ignore the prices. Much cheaper must go, you must buy
http://www.sau.com.au/forums/topic/442357-fs-sa-stagea-skyline-parts-garage-sale/
ok GO
R34GTT RB25 Manual Tailshaft
$200 $50
to suit coupe
great condition good unis.
R34GTT stock exhaust (cat to rear muffler)
$100 $30
great condition, great for trips to regency
(doesn't include the rear tips)
C34 RS4S stock exhaust
$100 $30
comes off an AWD
ISC FMIC
$50 $20
no leaks however its dented in one side, just flip it over and happy days.
Fits R34 and im sure most others
R34GTT wheels painted black
Bridgestone Potenza S001 tires
$700 $300!!!
good condition 225/45/17
....such good tires which are basically free for this price!!
Stagea C34 cargo blind
$200 $80
excelent condition.
not sure why i dont have a picture but you know what it looks like
https://www.sau.com.au/forums/topic/450233-fssa-must-go-very-cheap-parts/
no dramas,
for the info of others, the tires were bought new 3 years ago and were used on my daily gtt. they were replaced after 9 months when i bought my bigger wheels.
they have been stored properly in my shed since.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
