Put in 2nd hand coilovers to find out one was blown and spring rates were higher than they were supposed to be.
made for a very unstable ride, very unsettling when the back ends skips sideways when traveling straight.
especially if you are gunning it :(
my worst experience was not a modification, pulled an early model (I think about 1950 ish)Fiat convertible motor down put a new head gasket on, start it up and it would run for a minute and conk out, did this 3 times until I found a tinny tube in my pocket, stuffed around and found out where it came from and away in went.
Next day I went to work and on the way home a cement truck came through a stop sign and I went through a ladies brick front fence, through the windscreen and ended up on the bonnet.
Got off the bonnet , the lady came out of the house, had one look at me and fainted, shit I was feeling OK until then,haha
I win this thread. I don't even need to type.
Hi Greg
It must have been bad if you cannot talk about it :(
This is not a shop bashing thread, do not mention the builders name, just might help someone out if we talk about things that went wrong and why.
Pete
true story rant...
Took the advice of many and bought a set of Five-O Motorsport Redrilled High Flowed Garbage Side Feed Injectors. They were absolutely shit.. was unable to get a stable idle at the factory idle RPM and unable to get my AFRs to stoich.. Dead times they provided were absolutely rubbish, had to make up my own table to get the car to idle.
Even so, cruise was garbage, economy was garbage.. spray pattern? what pattern?
Anyhow, sold them on Gumtree - then spend $800 and converted to top feed Siemens DEKA IV injectors.. was awesome. I now cruise at 17.2 AFR and it runs perfect...
Moral of the story, side feeds are gay.
I would have thought with all of these power builds and people using the wrong clutches for for the power they have, putting stress on gear boxes, even what seemed to be the right combinations, going POP!
Advised to use the wrong turbo/s , fuel pumps,injectors, driveline, brakes that could not handle the hard driving and a lot of this does not come cheap :(
Then finding the right combinations to make it work for you but I guess it is also down to the driver in a lot of cases.Maybe high power cannot be contained for long ?
As a newbie at this, there seems so many different right ways to do everything and that also means many wrong ways to get what you want??????
I am and still trying to get the combination right to make me happy, taking out new parts, shit even a complete new forged RB26 bottom end, new Poncams B and other parts, maybe when you start doing these mods you are never happy and that is a worry , well :)
Fitted a bee*r rev limiter. Not to be hectic and spit flames, but because didnt want PFC fuel cut ruining the motor...
Read lots of hate on the net but thought if im just using it for ignition cut, how bad could it be?
Other than not working properly (doesnt like pulsar distributor+EFI setup), its made a mess of loom before the ECU.
Then my motor died from oil issues anyway. Good times.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
