Worst Modifying Experience
Nismo 3.2ish
 Share
WELL HERE WE GO....
Bought GTR
After 3 months Motor went Bang, cracking pistons, shattering valves, it did a really good job.
Fully rebuilt engine, decided to leave standard turbos because yolo (just for the run in stage, kesh was low)
On the way home from Full rebuild running the engine in and not boosting it i spat exhaust wheel of one of my turbos out my exhaust.
Got new turbos
AFM died on the way home.
finished run in
TPS died on the dyno
Fixed TPS
Split a rad hose
Fixed hose
ran for a while
Lost half my oil
Fixed everything again all is running better than ever!!!
until.
Got shit fuel two weeks ago and was misfiring on 14psi...
Cracked the shits, Haltech, no AFM, and E85
what will go next?
#GTRlife
Bought and installed brand new sard 540cc twin spray injectors, came in as a kit specifically for rb25, they are white
Engine ran rough, also sounded like Wrx throughout the entire rev range
Tried trouble shooting think one may be faulty, bought a spare injector and still the same
New owner put it into a 2jz aristo, punched the numbers in ecu, fired up, all silky smooth... They're a waste of time on skylines but fine on toyotas
Sard 550 reds were good in my old car
WELL HERE WE GO....
Bought GTR
Got new turbos
finished run in
Fixed TPS
Split a rad hose
Fixed hose
ran for a while
Lost half my oil
until.
what will go next?
#GTRlife
Hi Anthony
Made my eyes water :(
Seems I need to post a TLDR version here.
Will maybe write it out if I can remember it all
Had car for 7 years
is a daily (lol)
Done 27,000kms total in 7 years
This car is on
its 2nd chassis
its 5th engine (and third rebuild)
its 9th fuel pump
its 2nd diff (and set of axles!)
its 3rd set of suspension
its 4th? transmission
its 3rd ECU
its 3rd turbo
its 3rd (sort of) manifold
its 3rd fuel tank
its 4th set of tyres (in 27,000kms?)
its 3rd set of brakes (as in set of front calipers, discs)
its 3rd exhaust
as you can imagine, the non TLDR version of this is very long
..and still going
  • Like 4
Had car for 7 years
is a daily (lol)
This car is on
its 2nd chassis
its 9th fuel pump
its 3rd ECU
its 3rd turbo
its 3rd fuel tank
its 3rd exhaust
..and still going
Wow Greg that is true dedication! Out curiosity, have you worked out total cost of ownership ($ per km)? I've got mine for this and the previous car and they ain't pretty...
Holy Shit !
Hope you like working 3 jobs. :3some: to pay for this lot?
I take it you also track the car or you would be in jail by now going through that lot on the road :woot: or do you run sly grog :pirate:
Is it still your DD, got some pics?
All the kms done were cruising kms below the speed limit, off boost. Well not all, but relative to most people on SAU I really do drive like a grandpa.
I'd like to take it to the track one day, but the car has never been working.
It is currently sitting at an engine builder shop, with the engine entirely dis-assembled.
As for $ per KM, it's certainly somewhere around $2
$2 a KM , haha that would stop you going to the shop for an ice cream :woot:
If what you say is true (bullshit I think) I would change mechanics , maybe you are using a carpet layer to do this work for you or :pirate: ,LOL
  • 3 weeks later...
I'd like to put in my $0.02c and suggest.. the f**king silver dash. I mean seriously. Half the interior photos and sale threads et al have it, and it's infuriating. My car is also tarred with this.
Why yes, I did let my kindergartener suggest and paint my interior!
I'm currently sitting at $10 per KM hahahahahaha]
When this build is done I will be around $27 PK , only because I have not done a shit load of Klms
Whoa!
Ok so the Skyline's sitting at around $1.25/km and the Monaro was $1.90/km, all inclusive.
It doesn't sound that bad until you consider that at $2/km:
  • Melbourne to airport return costs $100 (50km)
  • Melbourne to Geelong return costs $300 (150km)
  • Melbourne to Sydney one way is $1,760 (880km)
Oh well, cars. But ouch.
 Share
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
