Hey guys, I have done a quick search but could not find anything on the forum about this topic.
The rubber stripping along the bottom of my passenger door is looking a little worse for wear an is frayed on the edge. Has anyone here had to replace/repair these before? Is this something any auto trimmer can do?
Thanks in advance.
https://www.sau.com.au/forums/topic/450256-v35-for-stripping/
It's the 80838M (RH) + 80839M (LH) here http://infiniti.sewellparts.com/oem-catalog/800B02-BodySideRear-G35Coupe-2005.html
I bought a new right hand one from sewell parts when i bought my car, shipping is a killer though and make sure you buy new plastic screws 80820C x9 i think. I forgot to get the screws but i got them from nissanparts cheap anyway. Not sure if they can get the actual strip.
They come painted so you'll need the right coded part which references the colour. e.g. 80838AM93A which is i think brilliant silver and the one i got.
I used infiniti parts to check the code as they show colours but they don't seem to have the strips anymore http://www.infinitipartsonline.com/auto-parts/2005/infiniti/g35/base-trim/3-5l-v6-gas-engine/body-cat/gaskets-and-sealing-systems-scat/?part_number=80839ac50a but they do have other parts with the same code. AM91D white?
Edited by scuttee
  • Like 1
"V35 For Stripping"... at first when I read this I thought you were parting with your V35... :unsure:
First I felt excited - that there may be rare parts up for grabs... Then I felt sad and disappointed - thinking that a car as beautiful as a V35 was being 'parted out'. :closedeyes:
Just read your post and realised you're literally looking for 'stripping' for your V35 lol :no:
I did a self repair of mine bout 4 years ago using some rubber seal adhesive I had at home and it has worked a treat but if you don't have any at home the price of buying some might be better spent on brand new ones.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
