Yeah mate I know about the warranty that's why I wrote do a sneaky uninstall if something does happen aha. But I'm not going to be smashing the limiter all day for flames etc so the only thing I'm worried about is the ceramic wheel on my turbo. But if it does go I'm not too fussed as I'd like it high flowed some time and that would give me more of a reason too
This thread is f**ked.
re34perGTT. Everything that Ben has told you about the capabilities of the factory ECU, the capabilities and usefulness of the Bee*r are all true.
You don't need it. It can't do anything useful for you. You would be better putting it in the bin (so that you don't sell it to some cock stroker who will install it and break his shit) and spending some money on Nistuning your ECU.
And if you need a flamey shooty douchebag rev limiter launch controller to get a near stock R34 auto off the liine without excessive wheelspin, you really should consider either learning to drive or buying a Corolla.
I'm just after which crank angle sensor wire and power wire to use from the ecu. And i got quoted $880 for a nistune install + tune and don't have the money and would rather get that done once more modifications are made like afm, injectors and turbo.
Got a manual box in the shed but won't be able to install it for a month or so. Want to test this thing out in the auto box and ecu first so if something does f**k up either a) uninstall and use warranty b) fix it while I'm doing tranny
Would appreciate help with this and not just messaging to try and dis this thread
Covers the turbo for $1200 and engine block and all internals for like 2-3 k ? Something roughly. It's a $600 warranty a got for free when I bought the car and it's only done 120k's so I doubt anything will go wrong with it unless I do something. So may as well make the most of it ahah
Ok. So this thread has at least 2 lessons for you.
I have also realised I can't be helpful in this thread. I sort of want to but theres an overwhelming urge to stir a pot, that you have put infront of me.
I'll just observe from here on....
Yeah I'll probably only use it for 2-3 runs and maybe to chuck up a vid on YouTube for everyone then disconnect it but for now I'm just looking to put it in knowing fully well of what could happen
No need. We can see it here. Sounds sick.
BOOOOOOOO! Thats gayer than Ricky Martin and Ian Thorpe on a unicorn trotting down oxford street and crossing the rainbow coloured zebra crossing FFS!
Red - any 12v power supply
Black - any earth
Green - pin 46
Yellow - pin 44/45
Make sure you play around with the knobs as much as possible even though you have no idea what it's doing.
Have fun.
Post videos.
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
