Yeah mate I know about the warranty that's why I wrote do a sneaky uninstall if something does happen aha. But I'm not going to be smashing the limiter all day for flames etc so the only thing I'm worried about is the ceramic wheel on my turbo. But if it does go I'm not too fussed as I'd like it high flowed some time and that would give me more of a reason too
This thread is f**ked.
re34perGTT. Everything that Ben has told you about the capabilities of the factory ECU, the capabilities and usefulness of the Bee*r are all true.
You don't need it. It can't do anything useful for you. You would be better putting it in the bin (so that you don't sell it to some cock stroker who will install it and break his shit) and spending some money on Nistuning your ECU.
And if you need a flamey shooty douchebag rev limiter launch controller to get a near stock R34 auto off the liine without excessive wheelspin, you really should consider either learning to drive or buying a Corolla.
I'm just after which crank angle sensor wire and power wire to use from the ecu. And i got quoted $880 for a nistune install + tune and don't have the money and would rather get that done once more modifications are made like afm, injectors and turbo.
Got a manual box in the shed but won't be able to install it for a month or so. Want to test this thing out in the auto box and ecu first so if something does f**k up either a) uninstall and use warranty b) fix it while I'm doing tranny
Would appreciate help with this and not just messaging to try and dis this thread
Covers the turbo for $1200 and engine block and all internals for like 2-3 k ? Something roughly. It's a $600 warranty a got for free when I bought the car and it's only done 120k's so I doubt anything will go wrong with it unless I do something. So may as well make the most of it ahah
Ok. So this thread has at least 2 lessons for you.
I have also realised I can't be helpful in this thread. I sort of want to but theres an overwhelming urge to stir a pot, that you have put infront of me.
I'll just observe from here on....
Yeah I'll probably only use it for 2-3 runs and maybe to chuck up a vid on YouTube for everyone then disconnect it but for now I'm just looking to put it in knowing fully well of what could happen
No need. We can see it here. Sounds sick.
BOOOOOOOO! Thats gayer than Ricky Martin and Ian Thorpe on a unicorn trotting down oxford street and crossing the rainbow coloured zebra crossing FFS!
Red - any 12v power supply
Black - any earth
Green - pin 46
Yellow - pin 44/45
Make sure you play around with the knobs as much as possible even though you have no idea what it's doing.
Have fun.
Post videos.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
