hey guys
Do u think putting bonnet vents on my skyline do any good...becuase i cant really afford to blow $1095 on carbon fibre/fibreglass bonnet so i thought puttin 2 vents on the bonnet may help ...even for looks wise too....here is the vents i wanna install with mesh....any comments would b great
thanx guys :D
https://www.sau.com.au/forums/topic/45028-bonnet-vents-help/
The vents are good and will look great as well. Yes the rain will get in the engine bay, but no it shouldn't wreck anything, unless you are place a vent right above your pod filter, then yes in the rain, you will suck water into your intake.
Where are the vents to be positioned on the bonnet??? Kind of like a Ford XR8??? Another cheap alternative to bonnet vents is a bonnet lift. The drop in temperature whilst the car is moving is quite substantial!
https://www.sau.com.au/forums/topic/45028-bonnet-vents-help/#findComment-919543
yeh i was thinking on doing it XR8 way but how do i cut the shape out?
i was goin to do a bonnet lift....but i heard on the forums that it changes the bonnet movements during an accident as its designed to fall down wards...
https://www.sau.com.au/forums/topic/45028-bonnet-vents-help/#findComment-919551
Easy solution, don't crash then!! I've done the bonnet lift on my car, and it made a HUGE difference to everything, the other thing if you want to start looking at lowering tempratures is to plate off the area between ur bumper and your radiator support panel so the air can only go through your radiator/intercooler...
https://www.sau.com.au/forums/topic/45028-bonnet-vents-help/#findComment-919695
u mean a radiator air guide obviously....well il try the bonnet lift ..i have the DIY guide from Autosalon mag so il try but...ive got my mind stuck on putting vents in but i cant visualise wat they would look like
https://www.sau.com.au/forums/topic/45028-bonnet-vents-help/#findComment-919720
I have vents on my R33. They look fair shit, but you can see heat pouring out when you pull up to a set of lights. I'm looking at replacing the vents with WRX style vents or buying a carbon-fibre or fibre-glass bonnet in the not too distant future..
na i dont think i would put WRX style vents on a skyline ...do u mean the honeycomb look ones?...im still leaning 2wards those vents i showed ....
https://www.sau.com.au/forums/topic/45028-bonnet-vents-help/#findComment-920769
Personally I like a squarer vent on the series 2 GTS ( assuming from your avitar ). Better suits the square front and flat bonnet. Something like what they used on the Sierra Cosworth bonnet.
Then again, have you felt the weight of the standard bonnet? That's a good enough reason to invest in a vented aftermarker one.
Z.
https://www.sau.com.au/forums/topic/45028-bonnet-vents-help/#findComment-921146
Hi, guys. I looked into putting vents in the bonnet and I am still very interested, but I was told by a couple of people that adding vents is against the ADR and that the cops are hot on it. Also, it is unlikely that the pits would pass them. I haven't got around to asking the inspectors at one of the WA pits, but I will try to in the next couple of days. Apparently, from a previous thread (can't recall which), they have two concerns: one is when the vent is facing backwards, they reckon you could get an oil leak that would spray oil onto the windscreen, thus hastening your demise through lack of forward vision. Second one is when the vent is facing forwards, all those nice sharp edges are not pedestrian friendly for those occasions when someone drops in unexpectedly for a little ride on your bonnet.
It seems that the powers that be are none too keen on fibreglass or CF bonnets, either. It seems that these will tend to shatter and rip to bits this pedestrian who insists on hitching a lift on the front of your car. I can understand this with fibreglass/GRP, but thought that this would be less the case with the stronger CF.
A bonnet lift will definitely not be passed by our mates at the pits - as far as I am aware.
I am still keen on pursuing vents. I like the R34 V-Spec vent. :aroused: I was also thinking of linking a vent to a cold air intake - the rain over the bonnet will definitely not be as bad as any splashes you get from a low mounted pipe in your front guard vent.
I am also looking at adding GTR vents to my front guard - the ones either side of the number plate. This should work on an R33 GTST SII and may give another option for the cold air intake inlet.
Meanwhile, P1E do you have any pics of your vents?
Cheers.
https://www.sau.com.au/forums/topic/45028-bonnet-vents-help/#findComment-921155
P1E is that vent for the air filter?
Looks pretty good. I was thinking of putting a NASA vent for the air filter. Something similar to the intake vent on the Evo 6. Was it an easy job to cut the hole on the bonnet? I was told that you might chip and crack away the paint if I was to cut into the bonnet. Another thing is what will happen if water get into the air filter?
https://www.sau.com.au/forums/topic/45028-bonnet-vents-help/#findComment-921298
Z.
hey u talkin bout these cosworth vents...
https://www.sau.com.au/forums/topic/45028-bonnet-vents-help/#findComment-921568
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
