Rb26 Plenum Install
Deziner
 Share
Hey all,
Is it possible to remove and install a stock plenum with the engine in?
I have searched for a tutorial and have not been able to find one.
If it is possible do I need any special tool? I have a polished plenum and gaskets.
Any advice appreciated.
Cheers.
If all the coolant hoses are original don't even consider not changing them. They're a ticking timebomb, and this job is a big PITA so you'll hate yourself if you have to do it again.
I would pull the motor out but thats just me. I have extracted so many engines i could probably have the engine out before you even have half the plenum unbolted
Agree, also gives you the opportunity to check out the hot side far more easily.
Did it over a weekend. Lots of swear words and painful in the end. If you are removing that side for whatever reason make sure you inspect all the hoses like everyone has mentioned as you don't want to have to remove the plenum again due to cracked hoses, lol.
You don't really need a tutorial to do it, you can locate all the bolts required to take the plenum off, but if its your first time will definitely take a bit as there are a few 'hidden' bolts that can be a pain to get at.
 Share
    • That is typical (for a rb at least) with a medium to large turbo, noting the format of the graph is probably misleading what you see a little (half portrait width but full height, in landscape it would look quite different) Basically until it hits target boost the torque curve is rising steeply, when that is 4000+ rpm it is not great to drive since almost all of your life is between 1,000 and 3,000 rpm. Once you hit target boost the wastegate opens and torque stops rising so quickly. From there the shape of the curve depends mostly on the cams and where they have a peak vs the rev limiter
    • Last of the maintenance items for now....not sure why but the drivers side window switch had heaps of wear on the right front and right rear switches Unfortunately, unlike earlier Skylines the controls are bolted to the door trim from the inside. So....off the with door trim. There are bolts or screws: Behind the door handle cover, pop it off from the handle side Under the rubber trim at the bottom of the door pull (also just pops up) Behind the courtesy light at the bottom. Other than that, just window down then pop off the usual selection of push in clips around the perimeter and the trim lifts up Interesting that they have a bolt on cover instead of the old school plastic held on by goop....I guess they prioritised sound levels over price Then, 2 screws and 2 plugs to replace the switch (looks identical to the Fuga/Q70 one incidentally) and put it all back together. Also much better
    • ok I understand, but the majority of turbo vehicles lose torque, or have a flat torque curve after the spool.  hence my initial misunderstanding. I didn't think this type of curve was possible
    • It is completely normal. Your original understanding is what was wrong, not what you see in the charts.
    • made with turbo and tuned by (hypergear)
