Trying to work out my fuel setup for an E85 conversion and I'm a little stuck with pump sizing. Was planning on fitting an R31 efi tank to my bluebird which is a straight fit and it will allow me to remove the surge tank, however, I have been seriously warned about surge.
With this in mind, I will probably have to revert back to keeping the surge tank and using a large in line pump suitable for E85. Previously you all have given me advice on big inline pumps, but I need to know how big?
Heaps of info on injector sizing but I want to know the flow rate I need for a minimum of 500hp at the wheels with a 4cyl FJ20 and I will be using 1400cc injectors.
These Holley pumps look pretty good but can I get away with the 100GPH pump? any suggestions..https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/fuel_pumps/efi_electric_in-line_pumps/
Thanks in advance.
https://www.sau.com.au/forums/topic/450307-fuel-pump-size-and-capability/
Aeroflow are a direct copy of the Holley pumps and have the same colour coding for the pumps. The red and blue models aren't methanol compatible but the black is. The black is 140gph.
Carter lift pumps aren't e85 compatible either. I've just gone through this myself and ended up with the aeroflow black since anything better was a substantial increase in price.
Where did you see the older style pumps online? (edit, just found it on the website but they are carby only) also, I take it the aeroflow black is working fine as a lift pump?
Currently I use the stock 35yr old carby pump as a lift pump on my car with no worries but obviously will need to upgrade for ethanol..
Still can't find anything online for exactly what flow rate pump that I can use.
Edited by Gareth87
You have found what flow your injectors need to have.
Convert the total flow the injectors need into gph.
Eg 1400x4=5600 cc per minute.
5.6lpm
X 60
=360 liters per hour.
Convert that to gallons.
Unreal, I just ended up with that calculation a few moments ago.. Only couldn't be sure how the flow would be affected under pressure.. Pump I'm looking at is 370LPH free flow and I can't find a pressure flow rate chart.
Thanks for the info!
Fuel pumps will typically lose flow when the pressure goes up. It varies between pumps substantially.
The free flow rating is as good as useless unless it's being used as a lift pump .
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
