Hi, i have recently installed a 5 stud conversion on my r32. I am at the stage where i cannot seem to get the rear brakes to clamp the rotor!
all the gear off a r32 gtst including
-brake booster
-bm44 MC-
-4 pot 5 stir up front
-2 pot 5 stud down rear
I have alson installed some g tech brake lines.
After bench bleeding the MC for all extraction of air, all outlets flowed nicely.
Installing the MC onto the booster and connecting the brake hard lines i then start form the rear passenger brake.
Using the 2 man bleeding method (open bleeder, brake pedal down. Close bleeder brake pedal up) and repeating this method until a clear, air free stream. Going around all 4 callipers at least 5 times.
After this the pedal feel was completely soft 2 thirds (2/3) of the way down then you would hear a clonck and symoltaniously the pedal will become hard. This also happens when the rear calliper bleeder is open, opposed to when bleed ing the front calliper when the bleeder is open the pedal goes str8 to the floor.
After taking it up the street I found out only the front brakes were working. (when the car is on the same pedal feel present 2/3's down nothing then the front brakes engage).
After being thoroughly confused i took the calliper off the knuckle and getting some one to depress the pedal i saw the brake pads close after the 2nd or third press of the pedal, Which i would presume after the 1st pump making pressure then the brake pads would move, so I'm thinking this eliminates the calliper being seized. So it must mean there is air somewhere in the system.
So here are my questions.
WTF is going on???
Could there be air trapped somewhere in the callipers? or the hard lines?
Is the MC f**ked?
How man bleeds or amount of brake does it take to completely get all the air out and get a nice pedal feel?
HELP please,
Seems like you do indeed have air in the brake likes that run to the rear, when you changed the MC air tends to get into the steel pipe that goes into the MC and will take quite a bit to move all that trapped air all the way down the lines into the caliber and out the bleeder, I would suggest to re bleed the rear brakes some more and see if it comes good
You didn't inadvertently install the calipers upside down did you? As in, fitting the left side caliper to the right and the right side caliper to the left. This would put the bleed nipple at the bottom of the caliper instead of at the top. And make it impossible to get all the air out of the system. It's an easy enough mistake to make.
  • Like 3
You legend! the nipples are at the bottom right now, i will flip them, bleed them again and let you know. Giving that you said it is a simple mistake to make that sounds very much like a thing that i would do and have done.
Glad I could help.
Don't worry, I've had several cars come in to the workshop with the same issue. Always after the owner had worked on the car themselves, but even by some pretty mechanically minded guys. So like I said, it's a slight oversight. Swap the calipers around and it'll be good to go.
  • Like 1
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
