Complete R32GTR 4.11:1 diff centre with aftermarket Kaaz 1.5way LSD installed. Purchased from another forum member last year didnt end up using it http://www.sau.com.au/forums/topic/434303-parting-out-my-602kw-r32-gtr/
$650. Brisbane. Will ship at buyers expense.
https://www.sau.com.au/forums/topic/450332-r32gtr-kaaz-15-lsd-diff/
wouldn't be interested in selling just the 1.5 would you - I'm running 4.3?
edit: never mind, i know i wouldn't sell it haha
Edited by LuckyTune
  • 5 months later...
