***For Sale 1998 R34 GT-T RB25DET 2 Door Coupe***
350rwkw Tuned for E85 Tuned by Trent at Chequered Tuning.
105,000km Serviced every 5000km
Custom purple
Reborn leather seat retrim with skyline logo.
Tinted windows
Holandia 300 Sunroof
Garrett GT3076R Turbo
Apexi Turbo Timer
Z32 AFM
Apexi Power Intake Pod Filter
Blitz Front Mount (Blacked out) Intercooler
Nistune Ecu
Injector Dynamics 1000cc injectors
Blitz Nur- Spec R Exhaust
Adjustable Tien Street Advance Suspension
Blitz Dual SBC – Spec R boost controller
Upgraded BOSCH Fuel pump
Spitfire Coilpack
Modified Automatic Transmission
Runs the standard housing with the internals upgraded / replaced by MV Automatics with items that should be good for 350rwkw+
Things that were done to the box:
* 2,800rpm High Stall Convertor
* Shift Kit
* Strengthened Bands
* Housing Strengthened
Volk Top Secret Gold 18x9 18x10 Wheels
Custom Car Audio system with Custom Boot install worth in excess of $5000
including diamond splits front and rear
2 x MTX T5500 subs mono block 4 channel Amp
Comes with 2 Brand new 265x35 Bridgestome Potenza Re11 tyres that have not yet been put on the rear.
Very Regretful Sale
A lot of money spent on this car
Change in circumstances has been forced to sell this car
$15500 neg Open to Offers
Edited by skwazza
Wow beautiful car, I am waiting for my GSXR to sell, before I buy not that it helps you too much.... but if it's still available by then I will be in contact. Don't settle for much less than asking price!
  • 3 weeks later...
  • 3 months later...
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
