Hey guys
My old v35 skyline is having some electrical issues. The car hadn't been driven for a few days, battery went dead. The immobiliser and alarm would not disable and pretty much all electrics did not work. Had the battery as well as the battery in the key replaced, the car started again. A few days later, the new battery went dead again. Back to the workshop, we thought it might've been the alternator but the workshop thinks it's the alarm draining the battery and not the alternator failing to charge the new battery. Has anyone had experience with this in the past?
Cheers
Hieu
https://www.sau.com.au/forums/topic/450392-v35-electrical-problem/
I bought a 2002 350GT Skyline 7 years ago and had some very bad times with the electrics.
Turn the ignition off and the lights, blinkers would come on and could not turn them off unless I disconnected the battery.
Go out in the morning and the battery would be flat, all sorts of crap like that but whenever I took it to a shop it was always OK, bloody nightmare :(
But the more I used it the less it happened and finally it was all good, stuffed if I know what was going on???
Not sure if others have had similar problems with the 350s ??
You can use a voltmeter to check if the alternator is working - you should be getting around 14v at idle.
To see what's drawing current (when the vehicle is off) measure the current draw and start pulling fuses. If you see it drop significantly you've likely found the culprit. The power supplies in the OEM headunit often fail and something simple like a globe in your boot/glove-box could be stuck on.
Tracing a parasitic current draw isn't the best way to spend a weekend, but it's better than dealing with a flat battery.
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
    • Which one did you buy? I have always wanted a decent inspection camera but have been unable to tell whether something is cheap junk or cheap junk chunk sold at just a bigger markup
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
