And so it begins...this build is going to be very different to '1 OF A'
The aim will be to keep everything standard where possible AND to use up all the parts I have gathered up from the previous build which I am guessing most of you reading this would have seen by now?
  • Like 1
https://www.sau.com.au/forums/topic/450417-bnr32-track-only-build/
Was going to order the Cusco cage below:
http://www.rhdjapan.com/cusco-safety-21-roll-cage-13-point-2-seats-through-dash-nissan.html
Anyone had any experience/issues with these?
Cheers
Hell yes, been waiting for you to apply your efforts from 1 OF A into a track orientated build!
Very interested in reading this one and seeing how it all pans out for you.
No doubt ill get some bad ideas from this but thats what its all about!
Keep up the good work Robbie, i expect plenty of pics!
Just trying to understand the idea. Standard as possible and track don't usually go together. What track stuff are you doing?
You're right there Richard! Standard gearbox, diffs, brakes, suspension arms, body work
For the medium term it will just be local track events at Qld Raceway and Lakeside, all of which I believe will be non CAMS sanctioned events such as the time attack series (run by Paul Ruzic)
Cheers Aaron! Definitely aiming to contain the dollars on this one but mate. Will get some photos up soon
In.
Just a heads up though, I wouldn't bother with a Cusco cage if you're planning on doing any CAMS events.
Thanks heaps Tim, I hear ya. Just unsure if I will ever get the time/money etc to get into any CAMS events...
Cusco cage is approx. $1,500 delivered and if things did change it would be reasonably straight forward to pull it out, sell it off and go for a CAMS certified weld in cage
I guess I should talk to a few fabricators here in Bris and get some quotes...can anyone RECOMMEND A ROLL CAGE FABRICATOR IN/AROUND BRISBANE?
Also, would be great to hear from others who have a CAMS spec cage already installed to get an idea of what it cost etc...
Will be a great build, good to see it will get used too!
In regards to cages, im getting an AGI CAMS spec bolt in half cage for the events I want to do in Vic. This will only cost me 650 (delivery would be extra if your not in NSW).
They do them all from bolt in half/full cages and also weld in, however that may not work for you.
Their quality looks spot on, and they just look professional.
Worth a look if your willing to spend 1500 on a non CAMS cage!
Best of luck with the build!
  • Like 1
Thanks so much for the info Brady!! Greatly appreciated mate. I've called and organised a cage with Dave from AGI. My initial impressions, as you mention, are that AGI are a very professional outfit who pump out a ton of quality work.
I called this morning and Dave had emailed me detailed info and designs within an hour or so! Some photos he sent through of their R32 cages:
I went with this:
C) Full Cage (6 point) Bolt-in – Main hoop, double diagonal brace (through hoop), backstays, lateral bars (front legs), windscreen top cross bar, harness bar with eyelets, and single door bars
· Mid Level specification – State Level race meetings or Drifting
· Supply: $1,600 inc GST
Notes:
o AGI Bolt-in roll cage kits are painted in a Satin Black (low glare) finish.
o Roll cage kits come complete with lower plates and high tensile fasteners.
o Roll Cage tubing is CAMS compliant 350 MPA CDS Mild Steel. MIG Welded.
o CAMS Roll Cage documentation is provided with kit. Please advise your VIN/chassis number when the build is complete so we can complete the documentation.
o Please note that the regulations have changed for CAMS approved roll cages from the JAN 2012. Additional bar work is required at a National level while some existing roll cage coupling designs have now been outlawed. Our 2014 spec roll cage kits meet the new requirements.
o If you’re intending to fit the kit yourself, please note that all our bolt-in roll cages are pre-drilled (roll cage connector to corresponding tube) unlike some kits on the market. We also check for accuracy and fitment on our in-house roll cage jig (see attached photo). If you’re comparing our roll cages to that of a rival product, please make sure your comparing like for like. Some bolt-in kits are not CAMS compliant while other kits don’t simply ‘bolt-in’ as suggested and require days of modification to install.
Is anyone running Sparco seats...?
1. http://www.racedeal.com/shop/item/sparco-sprint-v-seat
The next step up more than double the price!
2. http://www.racedeal.com/shop/item/evo-black
Can anyone offer feedback on either of these two options?
I was also looking at Velo options....
Ah perfect mate no worries, just spoke today to Dave myself (Adam is a SEMA lucky bastard!!) and ordered my half cage. Ive seen them up close, they are good cages dont think youll be unhappy. Plus for 100 dollars more youve got a CAMS spec cage, win!
I have a Sparco Pro2000 on a bride rail in mine. Bolted straight in, and hugs tight. Wouldnt want to be an over weight individual though haha.
  • Like 1
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
