Cool, I'd be interested to see how it works for you. I thought the Attessa relied on a signal from the ABS or something but I guess not.
So I have a power goal of 600 HP + at the flywheel
Garrett -5 turbos
Tomei dumps
Nissan manifolds
Standard head
Tomei cam gears
Tomei fuel rail & reg
Nismo 600cc injectors
Standard crank
Forged rods & pistons
ARC cooler
Haven't sorted front pipe yet...I do have one that's a bit beat up but was thinking of using it and trying to do a side exiting exhaust.
Something similar to this:
http://www.gtrlife.com/forums/topic/78553-exhaust-turn-down-track-pipe-any-interest/
Has anyone done anything similar?
My worry is the ground clearance for the turn-down piece that will be fabricated to bolt to the front-pipe exit as it won't have the trans tunnel to follow like a normal rear exiting exhaust does...also will most likely be quite loud?
It does, or at least the ABS is part of the Attessa computer. Hydraulic bypass won't affect the Attessa computer though.
On a side note, I disagree pretty strongly with the statement on their website "Removing ABS for a track driven car is a must and is strongly suggested. ABS modules are known to kick in under hard braking or in the wet unexpectidely. "
ummm....no
  • Like 2
Garrett -5 turbos
Tomei dumps
Nissan manifolds
Standard head
Tomei cam gears
Standard crank
ARC cooler
ECU of choice???
I am thinking it's going to have to be a Haltech Platinum Pro mate. Keen to have the ability to run 98, flex or full E85
Don't suppose anyone has one for sale...?
if you have the Kesh get the new elite. It shits all over the plat pro tuning wise.
Damn Elitists !
Is it available now?
Is there a comparison table of features Pro V Elite ?
Edit:
Not sure the new features of the Elite will make a difference to the 32 GTR
Maybe some easier tuning.
Looks to be aimed at newer vehicles and a wider variety
Edited by Sinista32
  • Like 2
Damn Elitists !
Edit:
Ultimate tunes have one being tuned right now, and went over it all with me. For a track oriented car it would make a difference.
ummm....no
With some decent tyres the kinds of line pressures you generate are enough to pretty much stop the old absent from working anyway. I can't remember the abs activating in the dry on track. Not in the wet either but it doesn't rain much over here either.
Also the cycle rate is so slooooow.
I'm running a full AGI cage in my car, easy to install quailty is second to non.
IMO. the chaces of going on your lid, isn't the biggest worry, it's side impact...The AGI seems up for the task.
As the 600 plus horse power.... Just empty your wallet now :no: .... IMO.... Good luck though, keen to watch the build
  • Like 2
don't be little girly Robbie.
E85 Flex all the way.
Then you get best of both worlds.
Just can't go passed E85 mate. Its well worth it.
  • 4 weeks later...
Cheers Nigel. Haha yeh spot on mate. Cage looking very nice...looks like you went for the top of line!
Yeah mate E85 is locked in now! Obviously Nismo injectors will now be redundant.
Been plenty happening on this but no time to get any photos/post on here
The following parts have been ordered/have arrived:
Tomei oil pump
Tomei cam gears
Tomei sump baffle
Tomei fuel rail
Greddy pulley set (aluminium)
Nismo gearbox mount
Kansai Service Transmission Member Collars
OS Giken O/H Kit Set A for TS2B Clutch Kit
Fuel set up still to be sorted, so far it's as follows:
Factory HICAS hard lines
1150cc Bosch injectors (stainless steel internals)
3L surge tank (anodised)
Holley Dominator 1800 fuel pump (ss internals)
Unsure on FPR - any suggestions?
  • Like 1
May as well go Tomei FPR while you're at it
Not sure it will be compatible with e85 long-term? (internally)
Also have purchased:
-5 turbos (near new)
Tomei dumps (near new)
Engine has been pulled down and the plan so far is:
N1 block (near new) - to be torque plate bored/honed, crack tested etc
Revised lated model OEM crank - to be linished etc
Ross balancer
Tomei oil pump (new)
Tomei sump baffle
Sump extension using plate ally (8.5L capacity)
Head - to be cleaned
ARP head studs
Hi Octane cam baffles
Nitto head drain kit
N1 water pump
Yet to look into:
1. Forged pistons
2. Forged rods
3. Springs
4. Camshafts
Any input/advice/feedback re the above 4 items is always appreciated! :thumbsup:
Edited by $$slowmedown
Do a complete nitto bottom end. Seriously won't regret it. Well priced and amazing quality.
Thanks mate. Will get a quote
what you u think I have in mine? so far I have had no issues with my Tomei FPR.
I think issue comes with time...I've been put onto this to help counter the breakdown/corrosion/gumming
http://lucasoil.com/products/fuel-treatments/safeguard-ethanol-fuel-conditioner-with-stabilizers
what I have been told however (yet to be confirmed) is that E85 rots R32 GTR fuel tanks over time.
If someone else can confirm this, will the slim shady please stand up!
Haven't heard that...anyone had any experience with this?
