  • Replies 167
guys, I will post prices after I find out how much I can buy the car back for, hence the EOI. If it is a good price I'll pass the saving on =)
bbenny the engine is complete. May seperate. honestly haven't though about prices as yet. open to offers to get a ball park idea.
MattR & others who asked - I really shouldn't be "chatting" but it may reduce the moderators work in the long run so no one has to ask anymore.
The car was left in secure parking under some units in Sydney. i went away with work. Came back to find the car sitting on a spare tyre and jack. they broke into the car park with an oxy torch, proceeded to break into the car beside mine from which they stole a jack and spare tyre. and the rest is history. Alarm was disabled blah blah. the police said it was a professional hit. they didn't find a single finger print.
Interest shown for the following depending on price and time frame...
Bocsh 044 pump
NISMO adj fuel reg
momo steering wheel-damaged, boss, nismo horn button
Adj camber rods (front)
custom polished catch can (legal style)
Nismo side indicators
Time frame in not an issue. CAR HAS BEEN WRITTEN OFF. Received the call a few minutes ago. Please PM me with offers. Whole car available, but has been added to written-off register and is needed to go through RTA before reregistering.
The stacker is fine, I'll find out the part no when i get the car back.
those who have Pm'd standby on prices pls....very busy atm. i will reply I promise, may just take a couple of days.
The engine may come complete, depends on who wants what. I will sell on a first in best dressed policy...if the price is fair it's yours. the engine was compression tested @2500km and all 6 pots were within 1psi of each other. Catch can has NEVER been emptied since rebuild even during run-in. Before I blew my engine it would quarter fill a month. It has been six months since rebuild and the catch can still doesn't register oil at the lowest mark.
Head was also fully reconned with new valve stem seals, 3 angle valve jobs, etc, etc to as new condition. Engine also has a HKS head gasket (1.2mm). Compression has been dropped .3 because of the modified squish zones(which can be seen in the pic) Pistons and rods were all balanced together. rod bearings replace with exact crank specs -not universal aftermarket. Bores were 360 degree verniered(check for ovalness) and lightly honed/de-glassed for ring bed-in. All exhaust head bolts have been replaced as the have a habbit of breaking no 6(like mine had).
i am more than happy to help you guys pull bits off. I have had ever part of the car apart myself at one stage or another. Just a pitty I could see the engine at full potential =(
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
