I still don't understand why? Lol they are only +1mm, not like its 2 Or 3mm. When clearly the aftermarket cams are 30mm base standard is 32mm.
So you don't keep throwing shims running smaller base circle cams. With the tomei buckets you use standard size shims, do the math mentioned above.
Or you could look for a one piece bucket and shim which, if it exists, would be at least as much as tomei plus you'd almost be guaranteed to have to buy a few more when a couple of the clearances end up being a little out. Subaru do this with the later ej's- makes redoing seats/refacing valves much more expensive.
Edited by doo doo
I believe there is a company in the US that make one pieces for Toyota UZ engines after not liking the standard shim over or shim under setup. Was ages ago I was reading it but may be worth investigating see if they made any for RB's.
Shimless is obviously the best way to go if you can sort it out.
Anyone running that kind of setup, what is standard practice for a head rebuild if required? I assume you need to grind the tips of the valves or top of bucket in order to reset lash after a valve/valve seat regrind?
If it was possible, which I don't think it is with standard valve lengths is using lash caps instead of shims. Far harder to flick a lash cap then it is a shim. But I don't think there is enough valve tip protrusion above the retainer on a std setup in order to utilise a cap.
  • 5 months later...
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
