Hey guys I brought a r33 a little while ago and have converted it to a n/a. It was fairly easy although it's now running low compression etc. I still have the turbo ECU in it as the car is running alright. Car is having some trouble starting but have been told that could be fixed if I get the car tuned? Does anyone know what it would take to have the car running decently. I am 16 so putting the turbo back on is pointless as I wouldn't be able to drive it. If anyone could help me that would be greatly appreciated.
https://www.sau.com.au/forums/topic/450493-turbo-to-na-conversion-in-a-r33/
This:
  On 08/11/2014 at 8:44 AM, hairdryer33 said:
Cant tune a stock ecu. Put na injectors and ecu in to fix starting issue.
Get used to cops pulling you over as it will always register in their system as a turbo car.
As stated above, stock ecu and stock injectors,
I think you would need some sort of engineering certificate when trying to register a turbo charged car as a non turbo? Emissions testing, exhaust pollution and all that kinda jazz? Im just guessing here...
  • 3 weeks later...
NSW has power to weight ratio of <130kw.
Turbo ban was lifted 6 months ago. You can drive turbo in nsw if it is under 130kw which the gtst is not. So i guess you have to convert to n/a and try get it under 130kw per tone. Which i think is what will happen if you convert it to rb25de. Seems like a f**king hassle, i'd just buy a gts if i was you and sell the gts-t
  • 5 weeks later...
if its in nsw it doesnt need engineering, it just needs a blueslip, as its no different to changing it to the rb25de that came in the car standard as well. then its registered as a non turbo r33 as if you bought a non turbo one. if its around sydney and everything in the car is legit and road worthy i can help you there provided you dont mind bringing the car to hurstville, if its a rubish car, rust, lowered, loud, dark tints, huge wheels or anything like that then i cant help though.
Edited by Scott Black
  • Like 1
^ if you're in nsw. This is 100% correct.
Any type of engine conversion that the make of car came with from factory needs a blue slip and change of engine I.D on the rego papers. And that's it.
There are also small loop holes when you really start looking into engine conversions of other makes. It's actually pretty cool some of the combos you can do.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
