Make: R32 GTST
Model:93
Milage:170,000km
Transmission:RB25DET 5 speed
Colour:black
Complied?Yes
RWC supplied?Supplied on sale
Currently registered?End of Feb 15
Price:$
14,800
Contact: PM or mobile 0404002142
Comments / Modifications: Bought the car stock in March 2005 with 140,000km. After almost 10 years of ownership it is time to let it go as I just dont drive it much these days. With a growing family now priorities have changed and it is time for someone else to enjoy the car. Has only done 30,000km in the last 10 years.
Pros
ENGINE
Built RB30DET
Weisco forged pistons, shot-peened stock rods
ARP rod bolts and head studs
Cometic MLS 1.3mm head gasket (recently upgraded)
RB25DET head
Stock RB25 camshafts
Adjustable Exhaust cam gear
RB25DET Gearbox
6Boost high mount exhaust manifold
GT35R with 1.06 Ex Housing
Turbosmart 50mm Progate External Wastegate (plumbed back into exhaust)
Plumb back BOV
Greddy Intake Plenum
Q45 Throttle body
Walbro fuel pump
555cc Nismo injectors
NPC button clutch
Haltech E11v2
450rwhp on 20psi.
SUSPENSION & BRAKES
SAU Group Buy Suspension kit:
Bilstein Shocks
Whiteline springs
Whiteline Camber and caster kits
Whiteline front and rear sway bars
R32 GTR front brakes
Standard rear brakes
OTHER
JVC touch screen head unit
12in subwoofer
Battery relocated to boot (Optima Dry cell battery)
18 x 8 Koyo wheels
Brand new tyres
eBoost 2 EBC
FMIC
3in Exhaust
Momo Steering wheel
Dual Thermo Fans
Central locking
Mongoose M80G Alarm (installed last year)
Cons
The body is not perfect. It has the several dents and scratches consistent for its age. The front bar, bonnet, roof and boot lid were recently resprayed.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
