Make: R32 GTST
Model:93
Milage:170,000km
Transmission:RB25DET 5 speed
Colour:black
Complied?Yes
RWC supplied?Supplied on sale
Currently registered?End of Feb 15
Price:$
14,800
Contact: PM or mobile 0404002142
Comments / Modifications: Bought the car stock in March 2005 with 140,000km. After almost 10 years of ownership it is time to let it go as I just dont drive it much these days. With a growing family now priorities have changed and it is time for someone else to enjoy the car. Has only done 30,000km in the last 10 years.
Pros
ENGINE
Built RB30DET
Weisco forged pistons, shot-peened stock rods
ARP rod bolts and head studs
Cometic MLS 1.3mm head gasket (recently upgraded)
RB25DET head
Stock RB25 camshafts
Adjustable Exhaust cam gear
RB25DET Gearbox
6Boost high mount exhaust manifold
GT35R with 1.06 Ex Housing
Turbosmart 50mm Progate External Wastegate (plumbed back into exhaust)
Plumb back BOV
Greddy Intake Plenum
Q45 Throttle body
Walbro fuel pump
555cc Nismo injectors
NPC button clutch
Haltech E11v2
450rwhp on 20psi.
SUSPENSION & BRAKES
SAU Group Buy Suspension kit:
Bilstein Shocks
Whiteline springs
Whiteline Camber and caster kits
Whiteline front and rear sway bars
R32 GTR front brakes
Standard rear brakes
OTHER
JVC touch screen head unit
12in subwoofer
Battery relocated to boot (Optima Dry cell battery)
18 x 8 Koyo wheels
Brand new tyres
eBoost 2 EBC
FMIC
3in Exhaust
Momo Steering wheel
Dual Thermo Fans
Central locking
Mongoose M80G Alarm (installed last year)
Cons
The body is not perfect. It has the several dents and scratches consistent for its age. The front bar, bonnet, roof and boot lid were recently resprayed.
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
