Hello All.
I recently got myself a R34 sedan, and have an annoying miss when it gets hot. One possibility is the coils packs failing which is common on the Skylines. I had a look at the coils and the car has two types of coils in it. Looking on the forums 3 look like they are Splitfires and the other 3 look like Nissan OEM.
My questions are : Am I correct on the different coil types.
Can having the different brands cause issues.
Do I only replace the OEM with splitfires or do i replace them all?
My final question is why would somebody just replace three not all of them, surely a skyline owner cant be that cheap.
Thanks R34_Bunbury
Edited by R34_Bunbury
https://www.sau.com.au/forums/topic/450519-coil-pack-question-different-coils/
Hard to tell with the pic but the one on the left is definitely not standard Nissan. Having two types of decent coilpacks (as far as SAU is concerned the only ones that are any good are splitfire and OEM) would not be an issue as long as they are still working fine.
My advice is to let the car warm up and then disconnect each coilpack one by one at the clip and listen for the engine sound to NOT change. When you take a clip of and hear no change from the rough sound you know that is the coilpack/spark plug that is at fault.
Thanks for all your replies
Will try the disconnect coils one by one trick if I get some time next weekend, will also look at the plugs. I too would prefer all the same depending on what I find will I will replace them all with splitfires as they are the SAU standard.
Hi L33sh from another bunburyite..
Since it's an used car and you've just taken ownership I would just fork out some coin and replace all the spark plugs followed by a brand new set of coil packs.
If you're after straight plug & play a new set of Splitfires would be the best options, if you're into DIY and a tinkering, go with a set of LS coils.
I would avoid any other coilpacks that aren't OEM (new) or Splitfires. I've used other brands and they're all garbage once you start putting down some decent power, they all fail.
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
