Happy Laps - Queensland Raceway 07-12-14
I promise I will not drop no coolant...
sooooo any other skylines coming along,i know its christmas and theres heaps of shit on,but this event is for you to enjoy,come along, give the car a blow out and talk some shit with everyone and just relax.YOU KNOW THIS IS WHAT YOU NEED. :) :) ;)
  • Like 1
Ralph is doing a better job selling this than me :P
Yeah, by reminding everyone that if anything goes wrong with their cars at happy laps you will be blamed for ending the session minus 25 minutes early and never hear the end of it.
I can see why people are so keen...
come on only joking with you,i just want to see as many skylines there to support their club as possible,and to gang up on those evos,there 6 of them coming already.Do you really want sau to become the eau because you couldnt be bothed coming to the last happylaps of the year?Just bring your skylines,and the magna can come too,nothing like variety.Show your cars some love,drive them...
we had already run for 30 minutes when your car blew the hose,so no body missed out on anything. :)
heh, yeah, closer to 55mins I think lol, that's why I said it finished 'minus 25mins early'
If they'd just kicked us off when they were supposed to then I wouldn't have blown the hose till I was on my way home...
so mike are you going to bring the 300 along would love to check it out.
Not sure, depends how I go during the week. Would like to finish my ignition upgrades and ducting before I go racing :(
I am keen to play, mind says dont do it til it is done properly tho.
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
