just signed up for a new house so i need to clear out my shed over the next two months(before the demo begins)
items picks below
r33 gtr bottom end $500
VARSTON 18x10 rims with 505 a050 rubber $1100
r33 non vspec rear end $800
r33 gtr ic setup complete $500 $500
stock r33 turbos $200
tomie type b 260 9.15 intake cam shaft $200
stock r33 gtr intercooler $100
stock bovs $100
R33 gtr rims with ao50 rubber $900
Os giken rebuilt twin plate $1200
located valley heights sydney
pick up or ship
pete
  • Replies 70
5-9, haha you where the one that beat me to it :(
Daaaamn yoooou Faaaatz :rant:
yea purchased for the dumps... thus the dump price
yurns will go epic on your 3 litre
Apparently Fatz you will trade stuff for beer,
Case of beer for the Greddy intake kit? :yes:
i do like beer but $$$ talk
Two cases for the turbs and dumps lol
Offer forth coming
do it!
do it!
haha if you still have it (doubt it) when i get the R back from E85 and i has cash leftover ill take it. No kesh at the mo
no dramas
drop us a line when ya feeling rich
added more stuff to the first post
They are T618Zs ( TD06SL2-20Gs ) and should make North of 500rwkws with all supporting mods
Hey Fatz, still trying to figure out what way I want to go, when I figure my shit out ill hit you up if you still have stuff
Can I get you to measure the 10cm housing outlet size pleeeease
Cheers Mate
Cheers Mate
will do when i get a chance
are these laggy turbos?
more laggy than a pt6466?
how much boost can you push through them on 85?
the engine they're for is an rb29
how do you think spool and boost potential will be up against a 6466?
these are 500rwkw plus turbos so they will suffer some lag
bonus is they come with the 8cm rear housing which will bring them on harder ( if thats what you need)
2.9 they would be pretty epic
compared to a 6466 no idea ( depends on engine spec and a whole lot of shit)
also, got pics of them fitted?
no sorry
just look like some stock low mounts with some flashy pipes
Hey mate.. do u have a front pic of the gtr fmic? Wanna see if it will tidy up nicely
i will endevour to get them out this weekend and take some picks
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
    • If you want the screaming "weeeee" sound, just let the gasket between the exhaust manifold and the turbo break a little. It'll go "weeeeeeeeeeeeeeeeeeeeeee" everytime its on boost...
