Went to fill up this morning, and the E-Flex pumps were taped off. Spoke to the guy behind the counter and he said that Caltex are no longer bringing in stock of E85. He said that a couple of servo's still have a few weeks' stock, and then that's it.
Anyone else heard this news? He suggested partitioning Caltex to keep E85 in SA.
So if this is true... then the only place left is United. For me, the closest is probably the Adelaide airport station (which I hope is 24 hours... might not be). Unfortunately, my tuner says the United mix is higher ethanol content (about E80-E85 compared to Caltex E60-E70 ish). This is good for power, but probably means a retune. Or a calculated mix with some added '98.
Nistune do flex-fuel sensors now, but that looks like costing another $2,500-3000 because a lot of re-tuning is required.
Anybody else running E85?
https://www.sau.com.au/forums/topic/450598-no-more-caltex-e85-e-flex-in-sa/
I thought there was one closer to me but I was wrong....
Caltex down Seaford way does not,nor did it ever as far as i know, stock E85.
Not sure of the nearest United to me but it is very annoying not to have the option :angry:
Haven't seen any E85 at the united's down south, being Adelaide it wouldn't surprise me if the airport was the closest one.
The airport one is 24h (or was...)
  • Like 1
At least it's 24 hours but yeah, 20 minutes for me too. Trouble for me is that my stagea is tuned for E85. I've got a '98 map but it's only for low boost, and there's a bit of messing around required to get it on the ECU because my consult port is on the blink at the moment.
I think I also need to get a retune to use the United E85 since it's properly 80-85% instead of about 60% (E-Flex) which my tune was done on.
Just add the approximate percentage of petrol and you will be fine, err on the side of rich and you will be more than safe enough. (your cold start will probably improve :P)
A wideband is a good idea for these situations, my new WB kit only cost $130us...
Shame the Caltex boffins are shutting it down, but I guess it just isn't viable for them now that United are in on it.
I had considered doing my own in-tank mix of 98 and E85 too... when you say to err on the side of "rich", do you mean err on the side of more 98 (lower % ethanol) or more E85 (higher % ethanol)?
The issue I think with the United E85 is too much ethanol means it will effectively lean out, as the burn ratio would actually call for more fuel, so I need to add some 98 to reduce the overall ethanol percentage probably to about 75% (to be safe)?
By my rough calculations (I'm terrible at maths), if 51 litres (ethanol content) / 60 litres (rough tank capacity) = 85% (united mix), then 45L / 60L = 75%... so I add about 6 litres of 98 and then fill the rest with E85.
Sound OK?
I think a wideband O2 sensor sounds like a good idea, and Nistune supports that now (although I'm mainly worried about the high load/max boost/max revs type scenarios). Where have you got your sensor installed, is it mounted permanently?
6L would be ok. I used to add that much anyway in winter just to help with chilly cold starts. 10L of 98 would work fine too. It isn't too critical, ethanol gives you a fair safety margin, and the chance you will foul plugs is minimal.
The wideband is standalone, you don't need to plug it into the Nistune. I use mine for road tuning and to make sure the mixtures are ok.
  • Like 1
    • Do the R32s run high or low impedance injectors?
    • It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
