No I'd use PayPal or the many methods of doing it safer that I've already mentioned. No wonder scammers succeed with idiots like you around.
Just saying.
Who's to say I've been scammed before?
I am not talking about something worth $5
When I sell something I have communications with the buyer, they have my phone and email but I get the payment first.
Buying on eBAy , check their rating and I use PayPal.
Private buys, I want as much info as I can get, phone and email a must,not just text, I will call them first. I would think everyone wants to be paid before sending items.
BUT I guess there is still a chance of being scammed but it helps to check what you can.
I would think your Bank would have a look at this type of thing. I got scammed through an ATM for $1800 and the bank sorted it and I was reimbursed and having an account # should make it easy :)
Additionally, get a copy of their driver's licence and or landline number.
As for Paypal, as a buyer I have never had a problem with it. But as a seller, to put it simply, I wil NEVER use it due to the simple fact that it can be used as a very easy way to rip-off sellers.
I know of plenty of cases where this has happened, and I am also sure there are "professionals" out there using it to 'buy' free items.
Hopefully this gets sorted out soon enough.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
