On 16/09/2016 at 7:31 AM, Duncan said:
Onky just realised that's a 5 door 1600....unusual!
We've been dragging the Leaf all around the state for the hillclimb champs, since the post above we've been to Grafton, Tamworth, Raymond Terrace and off to Canberra next weekend. Still going great, and yes we only get 250 to tank.....effortless but thirsty!
Looks awesome mate!
Love the wheel choice!
I don't suppose you would be willing to take some photos of where your tow bar mounts for me would you mate?
Technically an 8 door. There were three more in the back of the Stag.
I did take some pics of how it is mounted, not sure how helpful they will be though because there's really only 1 way to do it and anyone doing it should know how....
DS mounting to chassis rail from the outside
DS mounting to chassis rail from inside
Additional central mounting (through plate welded in spare wheel well)
No pics of the PS mounting because it's under the exhaust, heat shield and exhaust hanger mount.  But its the same as DS
Where it sits, it was made for non Dayz kit which made this install a pain back in the day
  • 5 years later...
This thread needs resurrection. Normally I use a Q7 for towing duties but that's been purloined for school run duties lately so I had to resort to using Farmtruck to pick up some pipes from the local rural supplies depot. First of two loads, which were better secured than it looks in the photo...
  • Like 3
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
