Hi I have a 350GT 04
I have just had the AC controls stop working...Like no lights or anything...But the stereo still works fine...I thought
these were on the same fuse so im guessing it not the fuse near the fire wall!
Also strangely enough the gear lever will not let me pull down into gear. there is usually a click when I press the brake then you can put into gear but there is no click..
im guessing its a fuse somewhere? I have checked all the fuses at the fire wall near the battery and all seem fine!
I can for now manually push s\down the white clip under the centre console which releases the gear lever!
Any ideas on the ac issue? im hoping its not the controls themselves!!
I saw on you a guy had battery power issues and resoldered 3 resistors I think were 508-509-510,,on the stereo main board or auto finisher board! maybe this is the issue?
Edited by chiefster1976
https://www.sau.com.au/forums/topic/450611-ac-dead/
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
