Yeah gear box was not full but did have some water mixed with the fluid, steeering rack and brakes are next as the box is getting fluid to see if it will move around the back yard without the assistance of my patrol dragging it. the box or motor I’m assuming will be in very used condition and shortly give up. But who knows. 🤞 i lsd got fresh oil and the old oil was not contaminated with any water.
Can't remember if you've done the diff yet, after my 33 went under water, it was full of water a long while later. Drained and refilled with oil. Mine hasnt been moved under its own power yet though, but inspection camera before refilling and it looked like it should be all okay. Let's hope bearings are fine ha ha!
Also about the NSX, the rear window doesn't open and there's no engine detail, however the bonnet does open, and the headlights can be raised. I've read some blog posts that it's a shame that the engine isn't shown but otherwise the model is decent.
I mentioned earlier that the other models in the series would cost more, the Cosmo will be 7500 jpy (AUD 74.44 today's exchange rate) and the NSX will be 9750 jpy (AUD 96.77) assuming they are still available. I assume all other models if/when they are released will sell for 9750 jpy (which is still a good deal I reckon!). For two 1/18 models in one box the weight will be around 4.5kg which will cost 11950 jpy (AUD 118.61) Still interested in those?
Steering rack might be full of water, same with gearbag....
