Just a thunk.... How about buying some PVC fittings from bunnings, making up a pipe that goes to cold air that a pod fits on, then taking that PVC to an exhaust shop and get them to make it out of stainless? Looks trick, doesnt need you to have the car off the road, costs about 8 bucks from bunnings and the pod sucks the cold air.
Course, if you are just redirecting cold air to the standard air box, ignore me.
(PS - And pod filters filling with water and blowing up and killing the engine and eating babies is BS :cheers:)
https://www.sau.com.au/forums/topic/45062-where-to-get-this/#findComment-919887
After driving in torrential rain for 30mins my mates stock airbox with cold air feed (set up behind an opening the front bar) had water sitting in the bottom of the airbox and the panel air filter was soaking wet.
what i have done is left the stock intercooler pipe below the pod in place (i have fmic with cross over pipe) and a heat shield. not the best but the safest for everyday driving i think.
my 2c :D
-rb25
https://www.sau.com.au/forums/topic/45062-where-to-get-this/#findComment-919921
This is my current filter/feed setup, all I need is about a foot of this flexible piping to extend it down the the front bar.
I have seen the black irrigation piping at Bunnings but I dont think it suits what I want and plus it comes in like 30 metres only or something, its really hard and not really flexible too.
PVC piping was my original plan but I have yet to find the right bends and to get it exactly the way I want.
https://www.sau.com.au/forums/topic/45062-where-to-get-this/#findComment-919964
Looks like some aircon stuff. Bunnings does have plastic irrigation piping - which looked like it would do the trick.
The air ducting piping you mentioned will be good, however a bit pricey.
irrigation piping is not the best idea is you want max power out your cold air induction, as this piping has lots of tiny holes in it. however it is cheap.
ideally its up to you which path you take. Personally i would go for some thick hose, ot BLACK intercooler piping, as Black is much betetr for keeping the cold air inside the pipes colder.
I hope that made sence. :cheers:
https://www.sau.com.au/forums/topic/45062-where-to-get-this/#findComment-919985
Woodworking places have HEAPS of this stuff.... off cuts and everything with heaps of sizes.
Call Gregory Machinery they are in Richlands (boundary rd i think) you just go straight thru the massive round about at the end of the Western / Centenery Freeway... Or better yet, just rock up and ask them about it, im sure they would hook you up no worries!
Good stuff...
Haro
https://www.sau.com.au/forums/topic/45062-where-to-get-this/#findComment-922101
Guest darrinspencer
Harvey hose supplies
3277 5466 at rocklea
I bought some similar stuff off them about 10 years ago
It was 3 inch black rubber with a spiral wound wire in it. It used it for a cold air feed aswell. I still have some left over which I going to use in my car when I get around to it.
I work in the a/cond game and have 100 to 500 diameter flex, but i would not use it on a car.
https://www.sau.com.au/forums/topic/45062-where-to-get-this/#findComment-923069
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
