Hello,
I am selling the parts listed below. All parts are new/un-used. Have only been taken out of their boxes in order to take the photos below. Have since been put back in their boxes.
2x Genuine Bosch Z32 AFMs with Tomei AFM plugs - $500 for the set
Genuine Nissan N1 Water Pump - $280
Genuine Nismo Reinforced Timing Belt - $120
Pick up only please. I am located in Madeley. Please PM or contact me on 0439657815.
https://www.sau.com.au/forums/topic/450652-new-rb26rb25-parts-perth-wa/
  • 4 weeks later...
