Hey guys
Since I finally got my RPM Plasma gauge back I straightly tried to place it in the cluster
So after blablabla I dod not only pull the actuall needle out, I also took the damn thin metal needle with the normal pointer is sticked on
After some trying around the gauge is not working anymore obviously ^^ Ive heard some time ago, that when you re not pulling the pointer carefully, you will pull that needle with out and theres some Kind of spring in the mechanism which you´ll almost never be able to put back on place
But still and before I am bying a new Cluster I wanted to ask if you got some help for me.
Like said, the Problem is not on which rpm´s I have to put the pointer on, it´s just completely out of order
Thanks and sry for bad english, cause I m german :D
https://www.sau.com.au/forums/topic/450752-rpm-gauge-needle-completely-out/
your plumb out of luck buddy
buy a 2nd hand gauge/cluster, remove old gauge and replace into your original cluster
or just replace entire cluster is the easier way
Don't touch the needles !
it will be correct if no one has fiddled with it.
