Hey guys
Been trying to find out how practical a e85 conversation would be for my na r34
Like wether it's worth the money or not
I have found stuff on turbos but nothing for na
I'd like to get a bit more power out of it whilst I'm on my ps and im getting it ready for a turbo later on
Cheers
https://www.sau.com.au/forums/topic/450784-e85-on-rb25de-neo/
Is your car stock now?
The only thing you would need is a Nistune chip and a tune which could come to $1000 - $1500
I would think that would give you a noticeable increase in power but not a massive one. A well made set of extractors would help but maybe not worth it if you are going to turbo it later. You should probably also get a more modern ethanol friendly fuel pump ($180).
If you do go ahead ideally you would do a before and after dyno run but to save money you could just measure your 80 to 120 time in third gear before and after.
it has a 3 inch cat back now and i will be putting on a hi flow cat soon
so i wouldn't i need to replace any of the fuel pipes or injectors? iv seen that ethanol doesn't mix with rubber very well
and are thoughs 255l/h pumps on eBay any good?
I would avoid ebay due to many fuel pumps being cheap copies and then sold as a big name brand like walbro.
Best to buy from a established dealer like Kudos motorsports etc.
I have seen plenty of e85 conversions done on the cheap, minimal gains but the other benefits can be a bonus. Should even work out cheaper to run.
Simply running 30% larger injectors will do the trick on the stock ecu. Might be a bitch to start in the dead of winter though. Injector pulse width adjustment boxes are a cheap option also, but they need to be 'tuned'. (Like injected gas systems) or even bumping the fuel pressure is an option...
It can be great fun playing with ethanol via simple methods, but I suggest you get a wideband fitted at least, just to check your wot mixtures. $130us for the WB o2 unit is hard to beat.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
