First start of the day runs crap until idled for five mins. Try to drive then it gets rougher and stalls, try to restart but winds over constantly (10seconds on starter sometimes) then when it does start I cant touch the throttle or it will stall again untill the idle smooths out. I have no other idle issues other than this. Rb25
Edited by hairdryer33
https://www.sau.com.au/forums/topic/450797-cold-start-v8-roughness/
I did, brand new pump. Problem is still there. What else could be causing this? It has a low cold start idle like its missing one or two cylinders then warms up and comes right. If it stalls when running rough its a bitch to start, almost like an old carby which is flooded
Cold start valve (the "torpedo" one) could be cactus. AAC valve may not be set correctly.
Could need a good clean of the injectors.
What is the condition of the spark plugs?
Will it start if you give it a bit of throttle?
Ls1 coils made no difference compared to stock. New plugs gapped to .8 2nd afm cleaned with proper electrical cleaner, two different cas, no difference. Dont need a consult cable, did the old check engine diagnostic check engine light for fault cods, none shown. Once stalled I have to hold throttle flat after about 10seconds of cranking it fires, but really rough. Tps has been reset and tested countless times.
There's not much that makes the car run.
There's not much that makes the car run bad.
Stop swapping ecu's as they are the least likely thing to fail. Cas, afm, injectors, and of course cold start valve, aac.
  • Like 1
That suggests that the engine is flooding, probably due to dirty injector needles not closing properly and letting fuel into the cylinders when its not needed.
So, time to rip out the injectors and have them sonic cleaned.
  • Like 1
Replaced fuel pump, made a big difference and drive 100% better but still the cold start issue remains. The part im looking for iac valve, is that one the same unit as the idle screw adjuster? If so, what does that other part do where its got the rubber ,pipe from the intake connecting to it?
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
