First start of the day runs crap until idled for five mins. Try to drive then it gets rougher and stalls, try to restart but winds over constantly (10seconds on starter sometimes) then when it does start I cant touch the throttle or it will stall again untill the idle smooths out. I have no other idle issues other than this. Rb25
Edited by hairdryer33
https://www.sau.com.au/forums/topic/450797-cold-start-v8-roughness/
I did, brand new pump. Problem is still there. What else could be causing this? It has a low cold start idle like its missing one or two cylinders then warms up and comes right. If it stalls when running rough its a bitch to start, almost like an old carby which is flooded
Cold start valve (the "torpedo" one) could be cactus. AAC valve may not be set correctly.
Could need a good clean of the injectors.
What is the condition of the spark plugs?
Will it start if you give it a bit of throttle?
Ls1 coils made no difference compared to stock. New plugs gapped to .8 2nd afm cleaned with proper electrical cleaner, two different cas, no difference. Dont need a consult cable, did the old check engine diagnostic check engine light for fault cods, none shown. Once stalled I have to hold throttle flat after about 10seconds of cranking it fires, but really rough. Tps has been reset and tested countless times.
There's not much that makes the car run.
There's not much that makes the car run bad.
Stop swapping ecu's as they are the least likely thing to fail. Cas, afm, injectors, and of course cold start valve, aac.
  • Like 1
That suggests that the engine is flooding, probably due to dirty injector needles not closing properly and letting fuel into the cylinders when its not needed.
So, time to rip out the injectors and have them sonic cleaned.
  • Like 1
Replaced fuel pump, made a big difference and drive 100% better but still the cold start issue remains. The part im looking for iac valve, is that one the same unit as the idle screw adjuster? If so, what does that other part do where its got the rubber ,pipe from the intake connecting to it?
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
