First start of the day runs crap until idled for five mins. Try to drive then it gets rougher and stalls, try to restart but winds over constantly (10seconds on starter sometimes) then when it does start I cant touch the throttle or it will stall again untill the idle smooths out. I have no other idle issues other than this. Rb25
Edited by hairdryer33
https://www.sau.com.au/forums/topic/450797-cold-start-v8-roughness/
I did, brand new pump. Problem is still there. What else could be causing this? It has a low cold start idle like its missing one or two cylinders then warms up and comes right. If it stalls when running rough its a bitch to start, almost like an old carby which is flooded
Cold start valve (the "torpedo" one) could be cactus. AAC valve may not be set correctly.
Could need a good clean of the injectors.
What is the condition of the spark plugs?
Will it start if you give it a bit of throttle?
Ls1 coils made no difference compared to stock. New plugs gapped to .8 2nd afm cleaned with proper electrical cleaner, two different cas, no difference. Dont need a consult cable, did the old check engine diagnostic check engine light for fault cods, none shown. Once stalled I have to hold throttle flat after about 10seconds of cranking it fires, but really rough. Tps has been reset and tested countless times.
There's not much that makes the car run.
There's not much that makes the car run bad.
Stop swapping ecu's as they are the least likely thing to fail. Cas, afm, injectors, and of course cold start valve, aac.
  • Like 1
That suggests that the engine is flooding, probably due to dirty injector needles not closing properly and letting fuel into the cylinders when its not needed.
So, time to rip out the injectors and have them sonic cleaned.
  • Like 1
Replaced fuel pump, made a big difference and drive 100% better but still the cold start issue remains. The part im looking for iac valve, is that one the same unit as the idle screw adjuster? If so, what does that other part do where its got the rubber ,pipe from the intake connecting to it?
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
