On my 93 R33, the brake pedal has a really bad habit of knocking you back or holding you in a spot if you apply pressure to fast, for example in a panic brake situation. This is BEFORE you even reach the initial bite point of the brakes. It has resistance with zero actual braking force and its totally dependant on how fast you apply pressure.
Lets say if you try slam on the brakes while you are driving down the road and see something, the pedal will get rock hard, completely keeping the pedal from getting to the point where the brakes bite. It will hover here no mater how hard yo press, the harder you press the stiffer it gets. After a few seconds it will start to move down again at its own rate (kind of like a shock absorber) and get into the point where the brakes bite normally. IF you ease the pedal slowly down during the first parts of the movement, getting past the initial movement slowly, you can then slam it down and it wont lock up on you.
What exactly is going on here.
The brakes are strong and dont have a lot of pedal travel otherwise.
Edited by sonicz
Something is f**ked.....
Are you able to pull the master cylinder and booster off?
If not take it to a brake place asap. That's some dangerous shit right there.
  • Like 2
Doesn't matter.
Has to be taken apart and fixed regardless. It could be the pivot point.
Doesn't change the fact it's extremely dangerous and a chat on a forum won't fix it.
  • Like 1
Maybe it came across a bit too dramatically. Its not scary bad, its just a bit strange and the brakes otherwise feel like they are working easily and normally. The car recently passed rego and a average driver they probably would not even notice it. I guess I could describe the brakes using the common "mushy" or "spongy" terminology, but only at the start of the pedal travel and then they bite down really well and strong. Normally when brakes a spongy they are spongy throughout.
I am going to change the brake fluid as I think it could be air in the brake fluid making things mushy. Use any Dot 5.1 grade right? Its ABS equipped.
The perfect analogy would be the shock absorber on your computer chair. Take the chair all the way to the top, then hold the handle which allows you to go down again and sit on it fast from a height whilst holding the handle. You'll notice it wont let you just slam the chair straight down, but rather resist you plenty initially, then ease of holding you back and let you go down at a faster pace
Edited by sonicz
Just changed the pads and fluid and its much better now. Looks like it was related to air and water in the old possibly never changed brake fluid. It still has about 30% of that stiffness left however so I wonder if it was done right.
Yea most of the old stuff out, though obviously some residuals would be left in reservoir tank and lining of components. I think the order was rear left rear right front left front right.
I had/have no idea that you cant mix synthetic and mineral based. Have no idea what the previous owner had. I used dot 5.1 from supercheap.
How come all the "good" stuff seems to be dot 4? Is that ok to use? I think dot 5 is the one not to use, correct?
I still feel like there is air in the system somewhere that gets pumped around, maybe stuck in the ABS unit, how on earth do you bleed that.
Edited by sonicz
Dot 4 is fine mate, wasting your money on 5.. You can't use dot 4 when the system recommends dot 5 as the seals won't like it..
But you can go away the other way as far as I know,
That order was correct
I had a lot of issues bleeding our brake systems, until I bought a vac bleeder. First time every time now and it's a one man operation.
Sounds like the seal is shot in your booster. Just grab another. I have an auto one here... (The manual booster is smaller I am told, to fit the clutch slave cylinder.)
Thanks for the tips guys. I don't think anything is wrong with my seals or components, at first I suspected it may be the case, but now I'm pretty sure it was just air in the system as they are a lot better now.
At the moment its ok, but still I don't feel it was done 100% right. IT seems the Skyline brake system is not an easy one to bleed, something in the design makes it that if you're not spot on and know exactly what to do you will have problems, certainly more so than other cars like mazdas I've owned.
Scotty, any info on where to pickup a cheap vac bleeder?
Edited by sonicz
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
