On my 93 R33, the brake pedal has a really bad habit of knocking you back or holding you in a spot if you apply pressure to fast, for example in a panic brake situation. This is BEFORE you even reach the initial bite point of the brakes. It has resistance with zero actual braking force and its totally dependant on how fast you apply pressure.
Lets say if you try slam on the brakes while you are driving down the road and see something, the pedal will get rock hard, completely keeping the pedal from getting to the point where the brakes bite. It will hover here no mater how hard yo press, the harder you press the stiffer it gets. After a few seconds it will start to move down again at its own rate (kind of like a shock absorber) and get into the point where the brakes bite normally. IF you ease the pedal slowly down during the first parts of the movement, getting past the initial movement slowly, you can then slam it down and it wont lock up on you.
What exactly is going on here.
The brakes are strong and dont have a lot of pedal travel otherwise.
Edited by sonicz
Something is f**ked.....
Are you able to pull the master cylinder and booster off?
If not take it to a brake place asap. That's some dangerous shit right there.
  • Like 2
Doesn't matter.
Has to be taken apart and fixed regardless. It could be the pivot point.
Doesn't change the fact it's extremely dangerous and a chat on a forum won't fix it.
  • Like 1
Maybe it came across a bit too dramatically. Its not scary bad, its just a bit strange and the brakes otherwise feel like they are working easily and normally. The car recently passed rego and a average driver they probably would not even notice it. I guess I could describe the brakes using the common "mushy" or "spongy" terminology, but only at the start of the pedal travel and then they bite down really well and strong. Normally when brakes a spongy they are spongy throughout.
I am going to change the brake fluid as I think it could be air in the brake fluid making things mushy. Use any Dot 5.1 grade right? Its ABS equipped.
The perfect analogy would be the shock absorber on your computer chair. Take the chair all the way to the top, then hold the handle which allows you to go down again and sit on it fast from a height whilst holding the handle. You'll notice it wont let you just slam the chair straight down, but rather resist you plenty initially, then ease of holding you back and let you go down at a faster pace
Edited by sonicz
Just changed the pads and fluid and its much better now. Looks like it was related to air and water in the old possibly never changed brake fluid. It still has about 30% of that stiffness left however so I wonder if it was done right.
Yea most of the old stuff out, though obviously some residuals would be left in reservoir tank and lining of components. I think the order was rear left rear right front left front right.
I had/have no idea that you cant mix synthetic and mineral based. Have no idea what the previous owner had. I used dot 5.1 from supercheap.
How come all the "good" stuff seems to be dot 4? Is that ok to use? I think dot 5 is the one not to use, correct?
I still feel like there is air in the system somewhere that gets pumped around, maybe stuck in the ABS unit, how on earth do you bleed that.
Edited by sonicz
Dot 4 is fine mate, wasting your money on 5.. You can't use dot 4 when the system recommends dot 5 as the seals won't like it..
But you can go away the other way as far as I know,
That order was correct
I had a lot of issues bleeding our brake systems, until I bought a vac bleeder. First time every time now and it's a one man operation.
Sounds like the seal is shot in your booster. Just grab another. I have an auto one here... (The manual booster is smaller I am told, to fit the clutch slave cylinder.)
Thanks for the tips guys. I don't think anything is wrong with my seals or components, at first I suspected it may be the case, but now I'm pretty sure it was just air in the system as they are a lot better now.
At the moment its ok, but still I don't feel it was done 100% right. IT seems the Skyline brake system is not an easy one to bleed, something in the design makes it that if you're not spot on and know exactly what to do you will have problems, certainly more so than other cars like mazdas I've owned.
Scotty, any info on where to pickup a cheap vac bleeder?
Edited by sonicz
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
