Duncan's Race Car - The Most Overdue Build Thread On Sau
made some progress on Neil's Radical's wiring this weekend, but stuff all on my car.
I did get this snazzy pressing kit of ebay which made short work of the subframe bushes http://www.ebay.com.au/itm/231667756034
Just put a correctly sized sleeve above and below the bush
turn the handle (OK, lots, and hard), and it is done
voila
This bush pressing kit looks the goods and would make a great Christmas present (I will have to leave the family some hints that I need one of these).
I have had so much hassle trying to fit Skyline sub frames and suspension arms into the press to replace bushes where this will fit in anywhere and be so much easier.
what, lunch was unpaid? you are a harsh boss...
Well I figured I'd spent soooooooo many weeks working on your shitbox that lunch should be on your own time. 3 cheese and vegimite sandwiches and a couple of bottles of water should have shut you up. Oh it did take you a hour to remember where you were up to on my shitbox as well.
Don't stress to much,,, your old girl will get some lovin AFTER this coming weekend.
Don't forget to buy the carbon sheet for you firewall blanks.
Cheers
Neil.
Just make sure you have some bushes to press in on chrissy morning Charles,,,a kids gotta be able to play with his new toys.
Cheers
Neil.
Now back to the Duncan build.
How are we going to remove all the shitty interior black paint before a complete interior respray?.
Personally I was thinking we keep going with a total strip of the car and get all the cars paint removed, soda stripped or something, I haven't really investigated to much, but I can. Anybody got any good ideas?. Like she's just about naked now, why not keep going and fix her damaged bits and vinyl coat her outside and freshly paint her interior. We have never had her so apart ever and I can't see us doing this again for some years so this seems like the right time to get it done. Trouble is it means he won't get to drive her till mid 2016 which will not make him happy.
Thoughts People.
Cheers
Neil.
haha none taken....I am thinking sanded and painted to....but by a professional, not me.
I did the interior of the nugget with a spray gun and it came up shit. Plus it didn't look particularly durable either
f**kign cars. Post is a year old next week but still future tense. everything always takes much longer and costs much more than you expect.
So, that was more like a 12 year history lesson than a build thread, but I intend that the thread will change a bit from here. I’m not worried about saying what actually happens, both the wins and mistakes that comes with doing pretty much everything at home.
The plan from here is to do a pretty big overhaul on the car, and the target (although not essential), is the NSW Production Car round at Bathurst in April. Upcoming jobs:
Replace the PowerFC with a Haltec including dash and flex fuel sensor
Strip the interior and properly prepare it, eg removing tar
Remove unneeded wiring (I’ve only ever added, not removed)
Replace all bushes and balljoints, they are a bit shabby after 10 years racing and 15 years on the road
New fuel pumps, hoses and FPR
Rebuild calipers and booster, replace ABS
  • Like 1
there was a question elsewhere about the oil filter/cooler/thermostat system and I realised there were no pics in this thread.
I have a large oil cooler where the a/c cooler is factory. Upside down to help it drain if I need to. Custom bracket bolted to the radiator support and I'm about to add another bracket between the bonnet catch support and the bottom (top?) of the cooler because I'm not happy with how much it can move when bouncing over ripple strips
Removed the factory oil/water interchanger, mostly because they are impossible to clean once a set of bearings have been through them and they are $400+ to replace from Nissan. I now have a Stagea mount which angles the fitting nicely to an Earls relocator. Dash 10 Teflon braided lines.
Remote filter locator in right guard between the intercooler hose and the BOVs
Earls thermostat behind the reo under the headlight. This required a whole heap of fittings and strange angles. It also has mounts for temp and 2 pressure senders (currently factory and aftermarket gauge, I am changing the aftermarket gauge sender across to the haltech sender but the same basic setup.
The thermostat requires a lot of fittings but I think it's worth it considering the range of ways the engine is used; driving to events, cold mornings, endures, hillclimbs etc.
Close up
Slightly better perspective of location
Setup has been excellent, no signs of running either too hot or cold even in the most challenging times including 40o+ 20min rally stage
BTW, anyone thinking of doing braided lines, make them up yourself. They are straightforward with instructions and care. The much bigger trick is working out how to mount and route everything because fittings take up a huge amount of space.
  • Like 5
Are you comfortable with the diy lines and fittings holding the pressure Duncan? I had one split and it made an almighty mess, lucky I was just cruising at the time. What are your thoughts.
well based on my awesomely wide experience of 1.....yes :) I guess it depends what failed for you, hose or fitting, and whether the hose was in good condition or possibly damaged?
I think enough people have used these types of fittings at all levels of racing to be OK with it. But it's a good reminder I should put some more padding around the hoses in a couple of places and monitor it for rubbing.
Its always good practice to either support/bracket both ends so there is no tension in the cooler or put some allthread throught both facesand put a nut either side of the flange faces to stop the cooler from distorting with heat, load and vibration. If they are in an easy to see spot bot a big deal but over the years have seen a few cooler split and dump oil over the track etc as they were not in visible spots to see the distortion from poor supported cooler installs
Good to know, mine failed at the fitting so it was probably a dodgy assembly, I was asking because not sure if its safer to go to pirtek or enzed that's all.
good to hear it was at the fitting really......making them was straightforward but there were things to check around the cut end of the hose and how far it pulls in while assembling that someone could get wrong. So far so good..
[/url]oil-setup1.jpg
yeah I really need to support both ends I think, especially since its a big/heavy core
Yeah hose split along the length of the hose so probably wasn't cut right so with the pressure and heat split it. Maybe the Teflon coating was damaged. Worth keeping an eye on I suppose. Cheers.
    • PRICE  : $1400 LOCATION   : NSW Central Coast FIT  :  All Nissan 350Z type Z33 and Infinity G35 Coupe. See delivery note. Hi, brand new, unused, still in the box.  ($1850.00 is what i paid ) My bad luck !!! I thought my right front  Bilstein was cactus so i bought the ST 's to replace all.  Turns out the right front is fine ( loose mounting after service  by a well known importer of Bilsteins ) So im selling the ST's. They are made by KW ( no intro needed ) . Iam on the Central Coast and im willing to meet up in Sydney metro, within reason and Newcastle.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
