Duncan's Race Car - The Most Overdue Build Thread On Sau
We paid $31k for ours, 1996 R33 GTS-T with 56000 kays. True M-spec I might add, not a car with add ons after the sale from factory.
Ha Ha yea Duncan it's very amusing trying to explain to them about their cars, I get much enjoyment. One that always pops up is the Power FC, apparently they are junk, but they still get sold for big dollars.
  • Like 1
On 27/08/2022 at 8:44 AM, Duncan said:
Mate, there would be new skylines owners on these forums from American that weren't even born then...
Lol
I hope some Muuurricaaaannnnnn buys mine.
I will then never own a Skyline again (I said that last time, and the time before I said I'll never buy a JDM shit box but ended up my 1st R33, now 2nd)
  • Haha 1
On 8/26/2022 at 2:50 PM, Neil said:
Sorry Ben, let me re-phrase that, I would have to be the longest single ownership person of a Skyline on SAU, Invoice date 06/09/2001.
I have you beat, Nov 99. What was the plate Duncan...HUJ-33 or something wasnt it?
Geez mate, they hadnt much earlier released the R34!
  • 4 weeks later...
Ha, well no progress lately so no updates. Given another upcoming wet summer I've been out on the tractor with the grader blade trying to get some driveway drainage in place, which in itself is an interesting challenge. And once that is done I'll have a few months of weeds to get ahead of for the same reason.
My guess is progress on GTR will be slow until later in the year. Kell is off to Great Tarmac Rally in a couple of weeks with Mel in a shitbox wrx instead.
No work worth updating on the race car, dealing with some minor surface rust / underbody / chipped interior paint etc. As they say in racing, its "good from afar, but far from good".  I'm also updating mounts for rally gear in the boot like spare wheel/jack/toolkit.
On the other hand, the 100m of the 1klm of driveways I have done went awesome in the big rain :)20221008_142439.jpg
The rest, not so much.
  • Like 1
I did a fair bit of prep work before the rain and then we got less than expected and spread out so we actually faired really well, you guys got pumped (you are up blue mountains way yeah?)
We're a bit south of there but same general area. This was the little river behind our place after 50mm of rain (back during the drought it took 150+mm for that)
  • Like 1
  • Sad 1
We had water over our driveway from dam overflowing for the first time ever recently, only a few inches, but it had to fill the dam and overwhelm the overflow first.
This was because our neighbours dam had blocked/spilled over, then he unblocked it so we had the overflow and the spillage coming at the same time plus the rain.
The water table is defs full.
Throw in some side drains on the low side every 50 meters or so
Control scouring with rubble drains, and put in the odd culvert
I build alot of unsealed roads with work, drainage will keep it open longer, but there is only so much drainage can do
erosion-sediment-control-unsealed-roads-field-guide-120410.pdf
Thats f**king awesome, thanks mate. I was just looking at the drains thinking they were going to need some larger rocks to stop erosion in the fast moving/steeper sections too, they are comparably cheap to bring enough of them in.
I've got a grader blade so regular resurfacing is no issue, I do need to bring in a massive amount of roadbase over time if I want to improve the actual surface meaningfully, but it is passable now, even 2wd in the wet
Culverts are a practical issue too....there are 4 places where I could do with them but that is a very expensive job - 2 lengths of pipe, excavator time to dig down, aggregate under them to keep them stable with a proper fall, headwall at both ends and a pit at the entry. For now I've just got a light ditch across the road surface at each location and just fill them back in every now and then.
We did put 2 proper culverts under the main drive - 4 lengths x 600mm pipe...cost about $8k but I've never seen them more than 2/3 full which is a win.
20220129_172959.jpg  Need to do the same under the mid dam road, it goes under all the time
Just had the lower dam overflows dug out, looks like they are 2x300mm which is probably not enough for big rain.
All of which will seem like a hell of a waste of time and money in 18 months when the drought returns and we are watching the bushfires roaring across the hills
  • Haha 2
  • 1 year later...
On 18/10/2022 at 9:15 PM, Roy said:
When does the airstrip go in for the Cessna Bird Dog?
Took me a while to answer that....
Funny thing is, the across the river neighbour did put in an airstrip, built a hanger, and buy a cessna, because strangely they aren't allowed to build a house on the property but there is no problem building an airport terminal :rofl:
They've used in 3 times, once for an attempted landing where they misjudged a little, aborted and missed the trees by so little that new underwear was required. Second time the landing stuck, then a few weeks later the plane left and never returned, so I don't think aircraft noise is going to be an issue.
Funny looking back through the last few posts too, I've spent a heap of time lately redoing the roads  and drains so I guess it is a 2 yearly thing to add to the calendar. Those big drains did overflow in the rain about a month ago so that is pretty disheartening....just a reminder that you can't stop nature I guess.
Uncle Duncan, send me some photos of the creek/drain/culverts, when it's low or dry, and also when it floods if you have any
Do you have an idea of how much water that part of the land and drainage would capture in a heavy fall
Does the whole creek/drain overflow up stream as well as downstream, or are the culverts the bottleneck, or is the water building up past the culverts and stifling the flow, or does the whole road go under
Are the culverts being blocked by dirt or vegetation during the event
A land survey would be handy to see where the upstream water is captured and drains down stream
I can roughly calculate the size of the drain and culverts required and speak to our surveyors and engineers at work to see what options there are
When it comes to culverts and drainage it all comes down to some math to work out what is required
People often underestimate the size of a culvert/drain
In saying this I won't be back at work for a week or so as I had my right shoulder rebuilt 12 days ago
Duncan just needs to start an epic open pit mine, let it store the excess water for him.
Call it a dam and the authorities won't say a word :P
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
