Duncan's Race Car - The Most Overdue Build Thread On Sau
  • 4 weeks later...
OK, finally warm enough to not freeze in the garage, so v1 of the rear panel rodent excluder is in place.
Cut a section from ally flyscreen mesh
The plan was to sika it in place, but happily there was flange on the unit so I used the magic of cable ties to install it.  I'll check it at the end of a season and see if its still in place...
  • Like 1
While I was rolling around on cold concrete (I'm too old for this shit, I need a hoist again), I noticed the v1 nocas rack from 2005 had broken in the accident, so out it came.
You can see the welds split on the left, but to be fair it lasted 15 years of race rally abuse before the tree was a hit too far
These days of course aftermarket is easy, I went GKtech because black and looks reasonable quality
I check the inner ends, they were in good condition (not original, I put them in about 5 years ago). Measured the distance between the inner tie rods ends to try and get the wheels pointing something like straight ahead until they get to an alignment and swapped the inner and outer arms over. The Gteck centre was 3.5mm narrower than the old nocas rack so I spaced the arms out with washers
When to fit the arms up and found out that the old rack was definately off centre, so I kept the same spacing but took 5mm from one side and added 5mm to the other. I'll try and point the wheels straight once everything is back together, and then will see how hard the alignment guy laughs when he checks my effort
I did have trouble with the nut on the left ball joint being stripped (possibly crash damage, who knows), and f**k me if I didn't actually have a spare of exactly the right m10x1.25 half height nut.
Happy days, 2 jobs down, 1 million to go
  • Like 1
Solid progress well done +1 get a hoist, cold concrete can F right off.
I still have my creeper but unless the car is up high on stands it can be a squeeze to get it under with enough space to work.
On 04/01/2017 at 5:19 PM, MBS206 said:
Before 2020 hopefully, that's when the supposed next armageddon will occur and you don't want to miss getting to take it for a spin one last time.
OMG, how right were you, the apocalypse did arrive in 2020!
I've fixed my web hosting in the last couple of days so all those missing pics at the start of the thread are back
  • Like 1
  • Haha 1
how on earth can you give due attention to a post and the overall situation if you are posting on a phone?
f**k I feel old some times. bring back the dos bbs.
  • Like 1
On 8/17/2022 at 8:23 AM, ActionDan said:
Legend, good work.
This forum needs an app again, doing this shit on a mobile browser does not tickle my balls at all.
@prank why no more app? $$??
No App. Get in front of a PC for the nostalgia.
Now we don't want to go back to far in the stone ages...... Windows 95 or 98 maybe......
  • Haha 1
On 8/17/2022 at 9:12 PM, Duncan said:
typical fcking millennial, not being able to tell the difference between gen x and their parents. have you moved out of home yet?
I have no idea how old you are brotato, but you sound unhip 🤣
At 40, yeah I moved out last week 😉
  • Haha 1
a little more seriously, I can't believe SAU is 20 this year. And, like this thread says, I've had the race car for 17 years (and about 17 engines....).
  • Like 1
  • Haha 1
Unhip 🤣
Would actually like to know the age group of the usual suspects here?
Thinking I may be hanging out in the retirement village..............
  • Haha 1
If people in the retirement village are driving GTR race cars it sounds like a pretty good place to be
  • Like 2
  • Haha 1
Yeah better than the matching number vin, engine and screws crowd .
On 8/17/2022 at 9:24 PM, ActionDan said:
40 here, last month
I'm 37 feel much older when I have to deal with under 30 crowd 😂😅
Think may have to move part of this discussion to Wasteland so @Duncan get on with his build thread.
Edited by robbo_rb180
  • Like 1
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
