The main difference between a v-spec and a non v-spec is the ATTESA systems used. The v-spec uses an ATTESA pro system which has a higher rate (about 10 times as fast) of checking the wheels for slippage and thus transferring power to the front. It also has a active differential for left to right power transfer. From most articles I have come across (and from driving the two myself), not many people can actually tell the difference in driving the two. The v-spec was (is) considered the top of the range, however the the physical driving differences are minimal.
I suggest if you want to find the best BCNR33 you can... look here
http://www.zele-international.com/search_33.html
*HINT: click on the yellow boxes*
Personally I would get a non-V-Spec I think stock it is a better road car for Australia with the extra ground clearance.
He was looking at an R33 not R32 GT-R...
Personally I would get a non-V-Spec so you can switch it into RWD mode (I have done it, I know you can do it, so don't question me!) and I think stock it is a better road car for Australia with the extra ground clearance.
How do you switch your r33 gtr to 2wd mode?
I've seen r33 gt-r's without brembo calipers, and every gt-r ive seen with the extra lip was a v spec.......if im wrong, im wrong.
Im just going by what i know to be correct at the time.
DEAR HPI,
I have just brought an R33 GT-R VSpec. Do you know how to install a switch to make it RWD, so i can toggle between the two settings for dynos and burnouts at the drags? By fitting the switch can it cause any damage to the box or the computer system?
Brad
It is not a good idea to try and trick the ATTESSA system on the R33 Series of cars. On this model, even with the system disabled, there is still residual hydraulic clutch pressure in the transfer case, which will cause massive slip if the car is placed on a dyno. Result? A stuffed transfer case.
Hope this helps.
You can make a R33 GTR RWD by removing the front shaft from the transfer case hence stopping all power going to the front wheels.
That's how we tune my car on a 2WD dyno anyway....
On the strip we use the HKS ETC to cut power to the fronts for burnouts.
Speaking of which............. :cheers:
Thanks leewah, i also remove the front propeller shaft. From Gojira's post he implies that a non vspec can be "switched" to 2wd. Removing the front shaft would be the same excercise whether vspec or not.
Yes that is what I mean, but again with the caveat that sock mentions...
Fixing that problem is simply a matter of cracking open a valve to relieve the pressure.
But you need to get under the car for that.
For just being an RWD idiot for a while the fuses are fine on their own but any situation where the front wheels will be static is a problem... Anyway, I apologise to the thread starter for mentioning this, I knew I shouldn't have
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
